Character Turns into Boxes
deeds0ldeeds0l Posts: 0
edited August 2014 in Daz Studio Discussion
Hi i'm new to DAZ. I must have changed something in the settings because whenever I move the character or navigated the camera the character's mesh turns into boxes. I would like to view the character in real time when adjusting the character. How do I do it?
Post edited by deeds0l on
    You need to go to Window > Panes (Tabs) > Tool Settings and change the During Manipulation (near the bottom) to 'Use Current (Off)'
    That should fix it :)
  • Cris PalominoCris Palomino Posts: 13,052
    edited August 2014
    Check the viewport drawstyle pulldown (little sphere on the upper right of the viewport window. It is set to Solid bounding boxes. You can set it back to texture shaded.
    edited: Ah, yes, I see it's happening when you move, so Jimmy's suggestion would hold for this. You can just use my info if you ever change the drawstyle by mistake. :)
    Post edited by Cris Palomino on
  • deeds0ldeeds0l Posts: 0
    Thank you very much
