Raincoat and Hat for G8M
Serene Night
I am looking for the stereotypical yellow hat like the Gorton fisherman wears. I have seen it called a sou'wester hat but also called a rainhat and the yellow raincoat.
I did try the freebie on sharecg, and it didn't work. Also tried the dforce wet weather gear. Is there anything else?
https://www.daz3d.com/just-wet-for-genesis-2-male-s-and-michael-6
I don't have it myself, I can't vouch for it.
https://www.daz3d.com/h-c-raincoat-outfit-for-genesis-3-male-s There's this, but it doesn't come in yellow.
https://www.daz3d.com/dforce-wet-weather-gear-for-genesis-8-males has a yellow raincoat with hood, but not the hat you are looking for.
Maybe you could make this hat work by applying the same surface settings as the raincoat.
https://www.daz3d.com/dforce-on-vacation-outfit-for-genesis-8-males
I think what she is looking for is one of these
Chohole is correct . That's the hat.
that may work. I will try it,
Hey thanks so much!
Here's Just Wet converted to G8M. I took the tourist hat Barbult suggested, tilted it back, made it bigger, and adjusted the scaling so it squeezed in a bit. I then copied the texture from the coat and pasted it on the hat.
It isn't perfect but it looks pretty good! Thanks for the suggestion.
Let me know if you see anything else that might work.
Like this?
Yeah! that is very close to it.
The jacket is from wet weather gear, linked by barbult.
The hat is modelled in blender. It is actually modelled for G8F as she already was in my blend file. So it is first rigged to G8F and then fitted to G8M and weightpainted to the head. Currently I just have the OBJ file, but I might be able to make it as a DS wearable.
