I'm getting random bad blocks in some of my renders
eric suscheric susch Posts: 137
The bad render blocks show up as magenta squares like in the center of this image. The problem in intermittent. If I re-render they are gone. In this 12 second animation there are maybe 10 random bad frames. Anyone have any idea why this is happening or what render settings I could play with to eliminate the problem?
I'm using the 3Delight render engine to a .tiff image series 1280 x 720 with everything else at default settings.
Computer:
Windows 7 SP1 64 bit
Dual Intel Xeon 3.1GHz
128 GB RAM
DAZ Studio 4.6.3.52
3Delight 1.11.3.52
  • Richard HaseltineRichard Haseltine Posts: 111,696
    That's a known 3delight bug when using Depth Mapped Shadows. Make sure that any shadow-casting lights are using ray traced shadows and they should go away.
  • eric suscheric susch Posts: 137
    Thanks Richard.
    There are indeed several lights with Depth Mapped Shadows. Boy, that's going to kill my render time but it's better than all the errors!
    Cheers!
  • SimonJMSimonJM Posts: 6,101
    I understand that if you don't exceed a total of 100% for all the DSM light intensities that will stop (or reduce) this happening.
    If it's just a few spots do a full render then after setting Spot Render tool setting to 'New Window' (Window> Panes(Tabs)>Tool Settings: set Active Tool to Spot Render), do a spot render of each area, save as png and overlay in GIMP, Photoshop, etc.
