HELP:olympia 6= unnecessary deforms on morphing the cloth
50Artknight0550Artknight05 Posts: 9
edited August 2014 in The Commons
Hi guys!
I’m having trouble on morping the suit that I made for Olympia 6, it doesn’t fit well. I modeled the suit on blender. I followed the tutorials and different tutorials for the morphing of my modeled suit. but it doesn’t work, I’m still having troubled for a couple of days for this.
Can someone help me with my troubles? Thank you in advance!
1st:
1. I exported the olympia 6 to daz and created a suit for her, and impoted it again to daz.
2. then I used transfer utility from olympia to suits.
3. it doesn't work well.
2nd:
2.then I converted the modeled suit to subd
3. then I used the transfer utility. it doesn't work well too
4. then I tried to play aroun with the transfer utility but still the same.
Here are some screenshots of what happen…
Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
Post edited by fixmypcmike on
  • fixmypcmikefixmypcmike Posts: 19,711
    edited August 2014
    If you're modeling around Olympia rather than the base G2F you need the "Reverse Deformations" option checked. (Reverse Source Shape from Target)
  • 50Artknight0550Artknight05 Posts: 9
    thank you but actually, I also did that one. I already use the " Reverse source shape from target. but the result is still the same.
    and I don't know why. should I use the base G2F model as my base model for olympia's costum clothing?
    Thank you! now I know what to do. I just used the base G2f and it works... :D
