Texture Weirdness - Specifically with BD models
AabacusAabacus Posts: 407
I have this issue with BD Cassidy, BD Roula, BD Sorcha and BD Vanja and BD Louisa. (see attached attached picture - the one with no smile - that illustrates the issue).
Other models load fine: See attached...the one with the smile is like everything else.
They render fine but the preview is really whacky. Is there a setting in the surfaces that I can change?
Thanks.
Edit: This is on a Mac by the way....
Post edited by Aabacus on
    Are they using a custom shader?
  • AabacusAabacus Posts: 407
    How can I tell if it's a custom shader?
    Select a surface and read the shader name near the top of the Surface pane.  Another possiblity is simply the use of some of the channels in the normal shader that the preview cannot display, like fresnel.
  • LeanaLeana Posts: 13,504
    Texture shaded preview can't handle complex materials, so that can happen depending on how the skin is setup. It's totally normal as long as they render fine.
  • SevrinSevrin Posts: 6,314
    Might be a skin based on Anagenesis?  I think her older characters used something like that.  It looks very different in the preview.  Renders well and quickly, though.
