Timeline keyframes for morphs?
marblemarble Posts: 7,500
edited April 2021 in Daz Studio Discussion
I'm trying to edit a walk cycle by adding some motion to the glutes. I am using the Zev0 glute morphs for G8F but the keyframes do not appear on the timeline when I adjust the parameters. When I select a bone and move it, a keyframe is created at that point on the timeline but not for morph parameters. I've searched the forum but none of the suggestions I have seen (like making sure TRSV is selected, etc.) have made any difference.
Ideally I would like to use Graphmate to fine tune and copy/paste keyframes but Graphmate doesn't see any keyframes for these morphs. Neither does the new DAZ timeline which is just blank for those morph parameters.
Post edited by marble on
  • Richard HaseltineRichard Haseltine Posts: 109,552
    You probably need to enable the right options in the filtering: T = Translation, R = Rotation, S = Scale, O = Other (e.g., morphs and other numeric non-transform properties), A = Alias, H = Hidden. You probably don't have O enabled, or possibly A if you are using something other than the root figure node.
  • marblemarble Posts: 7,500
    edited April 2021
    Sorry but no. I did read that advice in another thread during my search and tried enabling them all - made no difference. Looks like it is not possible to animate morphs.
    I have the Spring Dynamics product which boasts the ability to work with dFormers but with no explanation as to how. I tried but failed to get that to work too.
    Apologies: just tried it again with all of those options enabled on a base G8F and it did work this time. No idea why I couldn't get it to work yesterday.
    866 x 277 - 31K
    542 x 297 - 26K
