• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > 3ds Max Discussion
Daz to Max Bridge - Meet the Team
DAZ_samDAZ_sam Posts: 170
January 2021 edited January 2021 in 3ds Max Discussion
To know more about the new Bridge team look at the general discussion here:
https://www.daz3d.com/forums/discussion/469326/daz-bridge-support-is-here
Please post any questions Regarding Daz to Max here.
Public Repo is here:
https://github.com/daz3d/DazTo3dsMax
Technical Artist/Project Lead - @DAZ_sam
Software Engineer  - @DAZ_vish
Customer Service Agent - @Razzle-Dazzle3D
Post edited by Richard Haseltine on January 2021
  • LamabyteLamabyte Posts: 23
    March 2021
    I just downloaded the Daz to 3ds Max Bridge plugin and it works, but it exports G8 in the wrong scale. If I measure the character, it's 4 meters tall, and it doesn't fit the rest of my scene. With the regular FBX exporter, I can just select metric (and set 3ds Max to metric), and it's fine, but I can't find any option like this in the bridge plugin. I can't scale up the rest of my scene because I use v-ray, which means the scale of the scene needs to be physically accurate.
    Any solutions?
  • davegvdavegv Posts: 165
    March 2021 edited March 2021
    Any solutions?
     DAZ uses the metric system where 1 unit = 1 centimeter. If you set the units in 3DS Max the same ( and choose to rescale objects in said scene if they were not done in same scale, ie centimeter ) then your scale should work ok.
    and this is posted in the wrong area for general replies...
    Post edited by Richard Haseltine on March 2021
    March 2021
    Ok I found the problem. In Max if you change the unit scale, it only just changes the display of the units (it puts whatever unit you selected after the numbers), but it doesn't actually changes from imperial to metric. You have to go in to the system unit setup menu and change it there. This is just incredibly stupid and confusing imo. Why do you have the option to use inches but display it as cm? Max is just so annoying sometimes.
  • peter_4031821peter_4031821 Posts: 2
    April 2021 edited April 2021
    Using the latest version of Daz to 3DS Max Bridge to transfer Genesis 8 and 8.1 characters from Daz Studio 4.15 Pro into 3DS Max 2020.  Here are some questions regarding errors:
    Any props (e.g. Clothing such as Basic Wear) that use 3Delight materials will cause an error when importing into 3DS Max (see image) but iRay materials work fine.
    Morphs for Facial Expressions do not translate into Max.  Most of the body morphs do, with some exceptions.
    Also, when will the 3DS Max Bridge have support for tranferring Poses or Animation, as the Blender Bridge already has?
    Thanks,
    Pete
    406 x 158 - 36K
    Post edited by peter_4031821 on April 2021
  • onyxlee_9b3cce7f35onyxlee_9b3cce7f35 Posts: 70
    Hi, so happy to see the support for Max bridge!!! Thanks in advance!
    Here are a few posts I wrote to help other users to save some time. Maybe you can let us know whether some recent updates have fixed some issues or not.
    https://www.daz3d.com/forums/discussion/429241/time-saving-tips-daz-to-3ds-max-bridge-biggest-takeaways#latest
    Another issue is about the versioning. It's very hard to find the version of your installation. And there is no changelog or update reminder.
    https://www.daz3d.com/forums/discussion/458831/which-is-the-latest-version-of-the-max-bridge#latest
    Last but not least, I have been manually transferring materials from Daz IRAY to Max, because the Daz Bridge doesn't do a really good job on this. Hope this image helps your development on the next version. Also, other than the textures, the shader info needs to be transferred into max as well, such as SSS color and values
    The screenshot below is using VRay as an example. Of course, you can use any max materials in your future development.
    844 x 956 - 231K
    Post edited by onyxlee_9b3cce7f35 on April 2021
    April 2021
    Any support here?
  • alainmfboullardalainmfboullard Posts: 0
    June 2021
    I am unable to load the plug in in 3ds Max 2021 ..the bridge is installed in Daz and seem to process my animation but the plug in is not found in 3ds max  What am I doing wrong??
  • arturradukevic453arturradukevic453 Posts: 0
    June 2021
    hi you said you need the system unit menu and change it there ... how to do it step by step? can you say in a nutshell please?
    June 2021
    Customize > Unit Setup > Click the "System Unit Setup" button > Select (1,0) Centimeters as System Unit Scale.
    June 2021
    I know this is a pretty janky solution, but you can export the facial expressions as OBJ files, import them into Max, and pick the imported meshes in the Morpher modifier.
    The problem with this solution is that since these are mesh morphs, it doesn't affect the bones, so you can't use this method if you also want to use the facial bones.
    June 2021
    Artur manager employee monitoring
    You can express facial expressions as OBJ files, this is also a way out.
  • ENGMADELENGMADEL Posts: 0
    June 2021
    HI , why character comes frome daz  to max with out animation , i use bridge
  • 3dmorocco3dmorocco Posts: 9
    August 2021 edited August 2021
    DAZ To Max 2021 -VRay Rendering Engine.
    Is there a solution for this problem?
    Look at the picture of the vray rendering!
    Thank you !
    Post edited by 3dmorocco on August 2021
    October 2021
    I thing those meshes are the corrective morphs. You need to hide them in the layers (or scene) panel.
  • cuzcocuzco Posts: 0
    October 2021
    Hello,
    When I want to export a scene from daz to 3dsx max it always displays this message : and when I find myself with the scene in 3ds max, some objects are no longer correctly in place, how can I avoid this? Thank you in advance.
    [url=https://zupimages.net/viewer.php?id=21/42/7soe.jpg][img]https://zupimages.net/up/21/42/7soe.jpg[/img][/url]
  • opppoe_c02b0d86opppoe_c02b0d86 Posts: 59
    July 2022
    Encountered a bug where, in an object converted from a moving part to a static object, if a multi-dimensional sub-material had the same name as one of the above, it would not write an xml entry.
    Pictured: NYS1_Restaurant is missing three items:Glass,Wall,Door_furniture
    And obviously, the missing item, happens to have the same name as above.
    1474 x 512 - 157K
    259 x 444 - 25K
  • odjebausmikimausodjebausmikimaus Posts: 4
    September 2022
    how can the bridge be installed manually? 3d studio max is the only one not offering this option, contrary to all the other bridges on github. why?
  • philbeimheimphilbeimheim Posts: 0
    December 2023
    1. Download the product and navigate to where its downloaded. You're looking for IM00070895-01_DazTo3dsMax.zip.
    2. You need to find the installer AppData\DAZ 3D\Studio4\RunOnce\Daz to 3ds Max_Install.dsa and place it in the RunOnce folder in User/Appdata/Roaming/DAZ3D/Studio4
    3. Unpack the folders in DAZ Studio_4.5;4.x Public Build;4.x Publishing Build;4.x Private Build to your Content directory
    4. Unpack the #dsmax files to their relevant locations; everything in the zip file is placed in its respective folder.
    That's it. It will work. If the run once installer or other files disappear, simply replace them.
    December 2023
    Is there a way to control the list of morphs exported using the 3dsmax bridge?
    They can be controlled in a straight forward FBX export, with a dialog that really needs updating to something with tick boxes, but there's no way to do that in Daz to Max Bridge.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
