• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Installing Daz to Blender Bridge zip file missing
denisnormandindenisnormandin Posts: 158
December 2020 in Blender Discussion
Hi,
Can the zip file to install the Daz bridge to blender be downloaded manually?
The instructions to install the bridge sais that I must start by installing it in Daz Studio, then go to the Blender preferences and install the add-on from C:\Users\*YourUsername*\AppData\Roaming\Blender Foundation\Blender\DAZ 3D Add-ons\” and called DTB_v280-283.zip.
I don't have that.
All I have under C:\Users\*YourUsername*\AppData\Roaming\Blender Foundation\Blender... is \2.90\scripts\addons\DTB
No zip files anywhere along that path.
I'm using Blender 2.9
The export process seams to be working fine from Daz, but I can't import to blender since I can't find the right file.
Thanks
    December 2020 edited December 2020
    Mine was different from that. There was a folder named BLENDER_VERSION in %appdata%\Roaming\Blender Foundation\Blender
    If you have this folder, just copy everything inside it into your actual blender version folder, then start Blender and enable the addon in the preferences.
    178 x 104 - 7K
    Post edited by Lissa_xyz on December 2020
  • denisnormandindenisnormandin Posts: 158
    December 2020
    Thanks Lissa,
    My folder strycture is different but you have put me on the right track.
    Now the add on was listed and I have enabled it.
  • sunny29sheikhsunny29sheikh Posts: 0
    April 2021
    thx it work
    just copied  \AppData\Roaming\Blender Foundation\Blender\BLENDER_VERSION\scripts\DTB
    to blender 2.9x  (\AppData\Roaming\Blender Foundation\Blender\2.91\scripts\addons)
  • chasgiv4chasgiv4 Posts: 0
    June 2021
    This solved my issue but my god it was freaking confusing to get there.
    I just want to clarify this for anyone else looking at this cross eyed.
    Go to C:\Users\(user name)\AppData\Roaming\Blender Foundation\Blender\BLENDER_VERSION\scripts\addons\DTB
    Copy the DTB folder
    Go to your Blender folder.  Mine was on a separate hard drive because I only use my C drive for installing programs not saving my work.  Also so I get automatic updates with steam.
    Go to a Blender Version Folder named 2.xx (x's are variables so they can be any number i.e. 2.93 or 2.92) and continue through scripts and into the addons folder and paste the DTB folder under addons.  If you were in the DTB file it would look like this for your mapping.
    D:\SteamLibrary\steamapps\common\Blender\2.93\scripts\addons\DTB
    If you are running Blender, restart it and you should be able to find Daz to Blender addon in Blender.
  • LPIncLPInc Posts: 21
    March 2022
    denisnormandin said:
    Hi,
    I don't have that.
    Thanks
    March 2022
    C:\Users\Scott Lawrence\AppData\Roaming\Blender Foundation\Blender\2.83\scripts\addons\DTB
    still having trouble version of blender 3.0 help PLEASE...
  • robinforcerrobinforcer Posts: 0
    March 2022 edited March 2022
    Copy the DTB folder
    I dont follow what youre saying....what do you mean 'Go to a Blender Version Folder named 2.xx' , you mean create one from scatch in another location?
    Post edited by Cris Palomino on March 2022
  • evodance87evodance87 Posts: 0
    September 2022
    ive tried all of this. nothing is working. bout to quit 3d all together because they cant make things user friendly.
  • tam_c3df5332fctam_c3df5332fc Posts: 122
    October 2022 edited October 2022
    If anyone has a mac, then you can do a similar process to what is discribed above.
    From your desktop, click on the Go (Menu), followed by clicking on the "Go to Folder" option,  which will open a dialog box and type in "~/Library" - this will take you to your hidden Library directory/folder
    From the Library directory/folder, go into the "Application Support" folder and find "Blender"
    Within Blender, look for the version that you have installed. In my case I have 2.93, which the Daz3DIM and DazCentral installed the files into correctly, but since I could not see the DazToBlender menu, I thought that it did not work.
    Nevertheless, go into your version folder, such as 2.93> scripts> addons> AppData> Blender Foundation> Blender> BLENDER_VERSION> scripts> addons> DTB
    Copy the DTB folder and paste it anywhere easily found, such as the Downloads folder, followed by creating an Archive file of that directory/folder, by right clicking on the folder and choosing "Compress DTB" - this will create a DTB.zip file
    Open Blender> Edit> Preferences> Addons> Install - navigate to the newly created DTB.zip file and it will install with no issues - see attached screenshots
    If the above info might be too much for you, then the following is a dropbox link to the DTB.zip file that I used for Blender 2.93:
    https://www.dropbox.com/s/5hn1nr72qezl8fk/DTB.zip?dl=0
    853 x 869 - 204K
    764 x 687 - 120K
    Post edited by tam_c3df5332fc on October 2022
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
