UltraScenery - new territory [Commercial]
11718202223100
  • memcneil70memcneil70 Posts: 5,548
    @sandmanmax, I think both renders are lovely and are of a 'series' feel.
    Mary
    memcneil70 said:
    DIM has an update to UltraScenery - Landscape Features Volume 1 with a package date of 4/15/2021. Is this expected and okay to install?
    And now, UltraScenery - Features Volume 3 has an update in DIM.
    Are these safe to download?
    Volume 1 fixes a translucency issue mentioned a page or two back.
    Volume 3 fixes the reflections issue mentioned a few pages back.
    Thanks for the confirmation they are okay!
  • FishtalesFishtales Posts: 6,221
    Chilling Out
    I used Mossy Hollow for this image.
    2021-04-06 10:05:40.061 Total Rendering Time: 42 minutes 5.81 seconds
    Click on image for full size.
  • ArtiniArtini Posts: 10,504
    Looks great, Fishtales.
  • PraxisPraxis Posts: 275
    edited April 2021
    Run away!
    UltraScenery: River 2, Mossy Hollow 3
    With:
    I'm no artist:  This  image is entirely due to DAZ Studio + talented PAs + [Make Art] button. smiley
    1714 x 964 - 2M
    Post edited by Praxis on
  • alexhcowleyalexhcowley Posts: 2,404
    edited April 2021
    Stream 1 Oaks 1 Sycamore Scene
    My second attempt at performing dark and mysterious rites with the Alienator Pro script and the first one fit to be seen in public by decent, respectable folk such as yourselves.
    I first used Ultrascenery to generate a scene using Stream 1 and Oaks 1.  I then used Alienator Pro to replace about half of the Oak trees with some Sycamores.
    The scene took about 34 seconds to create with the Accelerator and a few moments to tweak with Alienator Pro.
    Render time was about an hour using my tame MSI Nvidia 1080 GPU.
    Cheers,
    Alex.
    3000 x 1875 - 2M
    Post edited by alexhcowley on
  • barbultbarbult Posts: 26,450
    edited April 2021
    There's a new tool in the store - HedgeMaker. It works well with UltraScenery. In can create a layer mask for use in UltraScenery, to block UltraScenery from generating instances in the location of the hedge. You can mask any or all layers in UltraScenery. In this scene, I masked the trees, grass tufts and long grass in the area where I created my hedge. I left the base grass alone, because I didn't want a bare ground under the hedge. A "hedge" is pretty loosely defined. It doesn't have to be bushes, or even plants. It can be any prop you want or any assortment of props. It can vary in width and can be dense or sparse. I created two hedges in this scene. One has lavender, daisies, and primulas. The other hedge has a few pebbles and dandelions along the edge of the road.
    HedgeMaker RC10 with lavender and flowers hedge on left and right USC Pines_001_BCam River E.jpg
    2000 x 1125 - 3M
    Post edited by barbult on
  • Praxis
    Wow... oustanding work.  Impressive!
    Thanks for the update.  I didn't realise this product was designed to complement Ultrascenery.  I've just bought Stonemason's latest so this is on my wish list for now but a purchase is definitely in the near future.
    Cheers,
    Alex.
    I am pretty new to UltraScenery, I think the best jungle environment would be mossy hollow right?
    And do you know if there is a sea ecology, like a coast / sea + seafoam / waves?
    • Landscape Features Volume 1 has a feature called "Coast 1" that you could use as a coastline, and the UltraScenery water has the ability to adjust the ripples, but not enough to form breakers on the shore. I don't know of any seafoam or large waves in any UltraScenery addon. Maybe you could replace the UltraScenery water with water from some other product????
    • Mossy Hollow is your best bet for a tropical environment. If you have Alienator Pro, you can swap the trees of any ecology for other jungle type tree props that you may own, to make your own type of jungle.
    • You can also modify any of the existing ecology JSON files to create your own ecology with trees, grass, etc. that you want to use.
    • You can experiment with Max Altitude of a low negative numbers to create a flat terrain with lots of water. Start with any Feature that contains water.
    Have fun and experiment!
    I used Coast 2, hid the water in the scene tab, and added Ocean Calm and Real Ocean Quiet Cove for the sea.
    https://www.daz3d.com/forums/discussion/comment/6017302/#Comment_6017302
    Chumly said:
    Praxis
    Thank you!  It was a lot of fun.
  • barbult said:
    krysis163 said:
    I just started with US and tried a picnic scene.
    But my first problem is, that the grass and flowers go through the picnic blanket and the genesis body.
    In another discussion https://www.daz3d.com/forums/discussion/comment/5464316/#Comment_5464316 they suggest either use InstaEdit or render two images, with and without grass and stitch them in Photoshop.
    I do not like the idea of the two-render-stitch solution. So I purchased InstaEdit and tried.
    It do what it promised, but the flower meadow from UltraScenery generates a mass of nodes. I limited it by only convert the instances overlapping with my picnic scene but even with that it generates 10-thousands of nodes.
    Is there any other possibility?
    @ krysis163 Yes, there is a much better option. What you need is a layer mask in the Build tab. The layer mask tells UltraScenery to NOT put any instances in the masked out area. What I would do is place the picnic blanket in the UltraScene and then view the scene with the built in Top View (not just looking top down from a perspective camera). Frame the scene so you see the entire terrain. Then take a screenshot of the terrain area. Then in an image editing program, make a mask with black where the blanket is, white every place else and a tiny bit of gray around the margin between the black and white. Crop the image to only include the entire UltraScenery terrain square. Save that image as a PNG or JPG file. Then in UltraScenery, load that mask image into every layer that you want to keep out of the blanket area (grass, trees, etc.).
    Return InstaEdit for a refund, if the only reason you bought it was to solve this problem. It has some bugs that were never fixed, and it is unsuitable for a large bunch of instances, as you discovered. Submit a help request to Sales Support to return it.
    Works perfect. Thank you very much @barbult
  • GoggerGogger Posts: 2,507
    edited April 2021
    I was very pleased with the result of taking a camera UNDER the creek water and getting a scene like these.  Ultrascenery - with an emphasis on ULTRA!
    3440 x 1440 - 660K
    1200 x 1920 - 482K
    Post edited by Gogger on
  • AnEye4ArtAnEye4Art Posts: 861
    Looks nice but some caustics on the creature and river bed will sell the scene.
    IKR! I tried using Iray Water Caustic Lilghts and didn't have any luck at an initial stab - need to start with a fresh scene, get the hang of it and revisit this scene.
    I was going to mention Iray water caustics lights as an option. Your scene has the bokeh effect that resembles suspended water particles. The scene has great DOF and nice lighting; it just missing the caustics in my opinion.
    The lights would be nice, but I simply love it now. It was a 'take my breath away' moment @Gogger.
  • HowieFarkesHowieFarkes Posts: 624
    edited April 2021
    Submitting to Daz very soon my Pacific Northwest sets. Here's something I put together with it.
    1000 x 1300 - 2M
    Post edited by HowieFarkes on
    Very nice indeed. I do like how the snowcapped mountain in the background compliments the scene.
    That is beautiful!
  • gitika1gitika1 Posts: 948
    Awesome!
  • davesodaveso Posts: 7,918
    wow...do the rock outcroppings come with it?
  • RGcincyRGcincy Posts: 2,862
    Gorgeous! I'll be out there for a few weeks soon. Can't wait to use this set to recreate the NW's beauty.
  • butterflyfishbutterflyfish Posts: 1,500
    Nice! I will definitely buy that.
    No, those are from one of Andrey Pestryakov's packs: https://www.daz3d.com/stones-hr-2
  • That is so superb it's almost beyond words.
  • thedoctorthedoctor Posts: 201
    Almost verbatum for what I was going to write when I saw this render. I cannot imagine how I could get along without Howie's tools. Bravo!
