Fog in LUXUS for Carrara question
Joepingleton
I have been trying to figure out how to recreate the fog effects from Reality 2 for DAZ Studio in Carrara with LUXUS for Carrara.
I have been trying the shaders from LUXUS for Carrara Resource. But I can't seem to get them to work right.
Attached is the kind of effect I get from REALITY2. Is there a way to create this effect with LUXUS for Carrara?
One of the shaders in PhilW's Luxus for Carrara pack is fog:
http://www.daz3d.com/luxus-for-carrara-resource-pack
I've never used it, so I can't say for sure, but Lux is the same render engine, whether accessed through Luxus or Reality, so there should be a way to do it. I'll try and break out that shader to check out some of the components to see if I can get a clear idea how it works.
I had been trying the dust shaders in PhilW’s Luxus for Carrara pack. I don't think I am using them right. I was able to combine the LUX render with a Carrara default render using the light cone feature. This is the result. Its better but not as pronounced as the Reality 2 experiment. More experiments are needed.
Some experimentation with Carrara lights using spot cone effect and a special light rig I made a long time ago
What do you think ?
Anywhere near the effect you hope for?
End results are boundless depending on settings eg light postion, colour, and general settings.
You say you are using Luxus for CARRARA - I didn't think it was available yet - any tips how I can get it?
I think it's in the DAZ store, but I could be wrong. Not sure where they're at for GPU rendering in LUX, bit Octane has a Carrara plugin in the works. Dustrider has been working with a beta I think. Could be wrong on that though.
Thanks 0oseven,
I love what you did with the light cones in Carrara. I can get a good effect with that method. My second sample used a combo of Carrara's light cone and a LUX render.
My question was about replicating what I did in REALITY2 for DAZ with LUXUS for Carrara. Since they both use the LUX render engine I should be able to do the same thing in both. Reality 2 has a fog object and a great tutorial that allowed me to do the sample image. I haven't found a tutorial on how to use PhilW’s Luxus for Carrara pack fog material to get the same results. PhilW’s Luxus for Carrara pack is awesome and saves a ton of time. I thank him for such a great product.
Evilproducer is right that you can buy LUXUS for Carrara from the DAZ store. The octane plug in sound great, though the $500 Octane price tag is a big problem.
Thanks evil and Joe - I was getting mixed up with Luxus and Octane - the latter is the one not available yet.
Ok - Luxux is free but needs a plugin to work with Carrara- or Daz?
So Joe, it apprears you are saying the Luxrender works differently for Carrara opposed to Daz Studio given that you say you are trying to replicate what you did with Daz and Reality2 - ( I understand Reality is just the name given to the Daz plugin for Luxus?)
Gotta say the DAZ /Reality/Luxus render looks good.
0oseven
Lux render engine is free and you need a plug in to work in Carrara and DAZ Studio. Reality 2 for DAZ Studio, LUXUS For Carrara to use with Carrara.
The difference between output seems to be due to how the plug in's work in each program. They pretty much work the same as you convert your materials to LUX materials. I like LUXUS for Carrara because it has more material options (this may be improved with REALITY3). The only problem I am encountering is how it handles Fog, but that's just my lack of knowledge of LUXUS.
Attached is a simple test using PhilW’s Luxus for Carrara pack Dusty Interior material. More experiments are needed.
I think there's Luxus for DAZ Studio, too.
EDIT:
Here is the Spheric Labs Store, here at DAZ 3D, where you can get "Luxus", which is for DAZ Studio, I believe, and "Luxus for Carrara" ;)
This one is a carrara spot with cone effect and a gel applied using an image - I thought result was "interesting"
Have been experimenting hard with these and other cone settings including adding a bit of carrara fog - not producing much worth posting but learning a lot !!
I guess Luxus for for carrara goes on the shopping list.
This is a sample from the Carrara Render engine. I do have Luxus for Carrara but I haven't tried it.
Wow! Fantastic render Ringo!
P.S. I have Lux and I try to use it but...I prefer Carrara. For me, and it's my opinion, is more simple setting shaders and ligts
Thank you Pimpy!
If by any chance you have the DP Genesis 2 Male(s) Shader Bundle Vol. I.
It contains a render stage with light sets etc.
Well I am using the render stage and the light set for this image. What I for this particular images is in one of the spotlight with light cones I I have a GEL image of a red sunset. This give the light cone the red colors.
On the other spotlight I am using just a yellow color light cone and as you can see it is coming from a different angle.
This one is the final render with Global Illumination and Indirect Lighting.
I think the other one looked great as well, Ringo.
Great renders
Maybe I'll just have to stick with the light cone from Carrara's default render
I decided to do some more experiments with fog in LUXUS and thought someone may benefit from my findings. This time with Urban Sprawl 2 The Big City from Stonemason.
Attached is a demo of a scene with different settings based on these shader base settings
Top Shader: Lux Surface;
Material: Lux Glass 2;
Interior: Lux Lux homogenous;
Fresnel: Other value of 1;
Absorption: Lux constant color: color:50% grey, value: 0.00;
Scatter Coefficient: Lux constant color: 50% grey, value: 0.05;
Scatter Asymmetry: Lux constant color: 50% grey, value: 0.05;
Exterior: NONE;
Area Light: NONE;
A: No fog settings
B: Base Fog Settings
C: Scatter Coefficient: Lux constant color: 50% grey, value: 0.10; Scatter Asymmetry: Lux constant color: 50% grey, value: 0.10;
D: Scatter Coefficient: Lux constant color: 50% grey, value: 0.25; Scatter Asymmetry: Lux constant color: 50% grey, value: 0.25;
So it appears that Absorption determines how deep the light appears. Scatter Coefficient and Scatter Asymmetry effect the blurriness.
Also attached is a image with all the effects combined in Photoshop.
Thanks for looking.
Very cool, joeping! Thanks for sharing!
Thanks a lot Joeping. I will consider Luxus.
Thanks for the kind feedback.
More experimenting with the LUX volumetric shaders settings above and Opus Magnum from Faveral.
Looks to me like you're getting closer!
Thanks EvilProducer, I am getting closer but there are still lots of problems.
More experiments with Carrara 8.5 Pro and LUXUS for Carrara. This time I was experimenting with the LUX volumetric shaders settings above and bulb lights with Sandy Bay Seaside Village from 3d universe.
View the stereoscopic 3D version at 3dLive
