MARSA Elements {Commercial}
13»
  • barbultbarbult Posts: 27,371
    Stinger said:
    And if I right click on MARSA Elements and install from the Content Library, ...
    Please don't do that! Installing from within Daz Studio is installing with Daz Connect. It has already been explained that these scripts may not work correctly when installed that way.
    Where is DIM configured to install content? Is that folder mapped in your Content Directory Manager so Daz Studio looks there?
  • StingerStinger Posts: 328
    edited April 2021
    Looks like I got the file path straightend out, and the error messages are gone.  Now, how do you get this utility to work exactly?  When I select a prop, the geoshell is NOT automatically added. I have to add my own geoshell, and then apply the MARSA shader to get the MARSA dialog box to open up.  And when the dialog box does open up, none of the sliders work.  Am I doing something wrong?
    Post edited by Stinger on
    edited April 2021
    After I select a prop, I run a MARSA script.  The snow script in this case. I immediately get an 'error occurred' message and to see the log file.  Here is the log file.
    2021-04-14 06:22:51.936 Loading script: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/marsa snow.dse
    2021-04-14 06:22:51.976 DEBUG: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/MARSA snow Cover.dse
    2021-04-14 06:22:51.976 DEBUG: PixName D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/MARSA snow Cover.tip.png
    2021-04-14 06:22:51.978 WARNING: QString::arg: Argument missing: Master translation control that amplifies the XYZ controls, snow
    2021-04-14 06:22:51.978 WARNING: QString::arg: Argument missing: Master translation control that amplifies the XYZ controls, Master
    2021-04-14 06:22:51.983 DEBUG: Create Elements 1 snow Cover D:/Daz and Poser Formats/Shader Presets/Marshian/MARSA Elements Shaders/MARSA snow.duf
    2021-04-14 06:22:51.991 WARNING: Script Error: Line 230
    2021-04-14 06:22:51.991 WARNING: ReferenceError: Can't find variable: ApplyPreset
    2021-04-14 06:22:51.991 WARNING: Stack Trace:
        <anonymous>()@D:/Daz and Poser Formats/data/RiverSoft Art/Common/RSElementsCoverFunctions.dse:230
    2021-04-14 06:22:51.998 Error in script execution: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/marsa snow.dse
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    edited April 2021
    wrong thread, removed.
    Post edited by Mark_e593e0a5 on
    edited April 2021
    I have my content configured to install on an external hard disk. The file path in DIM is 'D:/Daz and Poser Formats'.  Attached is a screenshot of my Content Directory Manager. See anything wrong?
    453 x 449 - 35K
    It looks OK to me.
    barbult said:
    It looks OK to me.
    Thanks for looking it over.  I'm still trying to figure things out here.  Here's the latest log file when I load a tree and try to apply the MARSA snow script.
    2021-04-14 18:56:47.271 Loaded file: maple tree08m 099k polys trunk.duf
    2021-04-14 18:56:47.566 Loaded image maple_trunk003.jpg
    2021-04-14 18:56:47.632 Loaded image maple_trunk001.jpg
    2021-04-14 18:56:47.858 Loaded image maple_trunk003_spec.jpg
    2021-04-14 18:56:48.108 Loaded image maple_trunk003_n.png
    2021-04-14 18:56:48.206 Loaded image maple_trunk003_dif.jpg
    2021-04-14 18:56:48.304 Loaded image maple_trunk003_bump.jpg
    2021-04-14 18:56:48.363 Loaded image maple_trunk003_displ.jpg
    2021-04-14 18:56:48.420 Loaded image maple_trunk001_dif.jpg
    2021-04-14 18:56:48.483 Loaded image maple_trunk001_spec.jpg
    2021-04-14 18:56:48.545 Loaded image maple_trunk001_bump.jpg
    2021-04-14 18:56:48.685 Loaded image maple_trunk001_n.png
    2021-04-14 18:56:55.840 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/31/64931/meta/64931_1116f8_file.json) failed: HTTP response code said error
    2021-04-14 18:56:55.840 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (64931) failed, url: https://cdn.daz3d.com/file/dazcdn/p/31/64931/meta/64931_1116f8_file.json
    2021-04-14 18:56:56.023 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json) failed: HTTP response code said error
    2021-04-14 18:56:56.023 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (80611) failed, url: https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json
    2021-04-14 18:56:58.064 Loading script: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/marsa snow.dse
    2021-04-14 18:56:58.107 DEBUG: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/MARSA snow Cover.dse
    2021-04-14 18:56:58.108 DEBUG: PixName D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/MARSA snow Cover.tip.png
    2021-04-14 18:56:58.110 WARNING: QString::arg: Argument missing: Master translation control that amplifies the XYZ controls, snow
    2021-04-14 18:56:58.110 WARNING: QString::arg: Argument missing: Master translation control that amplifies the XYZ controls, Master
    2021-04-14 18:56:58.114 DEBUG: Create Elements 1 snow Cover D:/Daz and Poser Formats/Shader Presets/Marshian/MARSA Elements Shaders/MARSA snow.duf
    2021-04-14 18:56:58.119 WARNING: Script Error: Line 230
    2021-04-14 18:56:58.119 WARNING: ReferenceError: Can't find variable: ApplyPreset
    2021-04-14 18:56:58.119 WARNING: Stack Trace:
    2021-04-14 18:56:58.123 Error in script execution: D:/Daz and Poser Formats/scripts/riversoft art/marsa elements/marsa snow.dse
