Problem with Ginny 8.1 and G8.1 in general SOLVED
wsgentry
Hi,
I've got a strange problem with G8.1 females and particularly Ginny 8.1 from Mousso. Faces are just too angular and do not represent what is shown in product images--see attachment. Additionally, Ginny does not show up in smart content until I load a G8 character. If I don't use smart conent the character shows up but still has the angular facial feature issue.
I've tried using Ginny 8.1 character attributes in "Actor", but unless I turn off Ginny's 8.1 attributes via slider, the angularity remains.
Is there something I'm missing or is this a general G8.1 female thing. If the latter is there a workaround?
Thanks!
Scott
Post edited by wsgentry on
Oh...
I've deleted everything G8.1 related and reinstalled only Victoria 8.1 and Ginny, same thing. The G8.0 version does not have the problem.
Scott
Fixed! Found the fix here: https://www.daz3d.com/forums/discussion/436812/i-messed-something-up-and-now-genesis-8-always-loads-with-preapplied-morphs#latest
and this is it:
To fix any ill-behaving morphs, do as follows;
1. Load your base figure or the developer version to an empty scene. ("Genesis 8 Basic Female" or "Genesis 8 Female Dev Load")
2. Select the figure
3. Select "Show Hidden properties" in the Parameters-Tab, drop down menu (right-click)
4. Zero the figure (Found in Parameters-Tab, drop down menu)
5. Memorize the figure (Found in Parameters-Tab, drop down menu)
6. File->Save As->Support Asset->Save Modified Assets
This procedure will zero the default value in the ill-behaving morph/morphs, and while saving DS also shows you a list of the morphs it is changing.
Thanks to PertiA for posting that fix! :)
Scott
