Problem with Ginny 8.1 and G8.1 in general SOLVED
wsgentrywsgentry Posts: 573
Hi,
I've got a strange problem with G8.1 females and particularly Ginny 8.1 from Mousso.  Faces are just too angular and do not represent what is shown in product images--see attachment.  Additionally, Ginny does not show up in smart content until I load a G8 character.  If I don't use smart conent the character shows up but still has the angular facial feature issue.
I've tried using Ginny 8.1 character attributes in "Actor", but unless I turn off Ginny's 8.1 attributes via slider, the angularity remains.
Is there something I'm missing or is this a general G8.1 female thing.  If the latter is there a workaround?
Thanks!
Scott
1143 x 777 - 608K
Post edited by wsgentry on
  • wsgentrywsgentry Posts: 573
    Oh...
    I've deleted everything G8.1 related and reinstalled only Victoria 8.1 and Ginny, same thing.  The G8.0 version does not have the problem.
    Scott
    Fixed!  Found the fix here:  https://www.daz3d.com/forums/discussion/436812/i-messed-something-up-and-now-genesis-8-always-loads-with-preapplied-morphs#latest
    and this is it:
    To fix any ill-behaving morphs, do as follows;
    1. Load your base figure or the developer version to an empty scene. ("Genesis 8 Basic Female" or "Genesis 8 Female Dev Load")
    2. Select the figure
    3. Select "Show Hidden properties" in the Parameters-Tab, drop down menu (right-click)
    4. Zero the figure (Found in Parameters-Tab, drop down menu)
    5. Memorize the figure (Found in Parameters-Tab, drop down menu)
    6. File->Save As->Support Asset->Save Modified Assets
    This procedure will zero the default value in the ill-behaving morph/morphs, and while saving DS also shows you a list of the morphs it is changing.
    Thanks to PertiA for posting that fix! :)
    Scott
    1119 x 779 - 627K
