Strapless Dress dForce Collection G8F
SquishySquishy Posts: 727
edited April 2021 in Freebies
A collection of models of ladies' dress, rigged in DAZ Studio for Genesis 8/8.1 Female, intended for use with dForce dynamic cloth simulation. Basic and Hi-rez (subdivided) versions are included; both models share the same UV map and any textures for this item will work on both versions. A good assortment of Iray materials are included, as well as some shaders that allow for various degrees of transparency simulating thread weave.
Four skirt lengths are included: Ankle length, knee length, mini, and micro.
High poly versions are included because they can wrinkle and fold much more than the base version; depending on what you want this may not be important to you. Working with the high rez version takes quite a lot more prep time so be aware of this before choosing. Low-poly versions are also included with this set!
SEE DOCUMENTATION FOR IMPORTANT INFO ON USAGE!
Update 04/02: A texture artist reported a problem with the UV map on several of these, this has been fixed and updated; the problem was right at the seam and wasn't visible with the included materials but if you wanted to use other materials, you might want to take this update
https://sharecg.com/v/97371/view/21/DAZ-Studio/Strapless-Dress-dForce-Collection-G8F
Post edited by Squishy on
  • SquishySquishy Posts: 727
    A texture artist pointed out a problem with the UV map for many of these, which I'm working on fixing. Waiting on a confirmation of whether the fix works or not.
    Update is in place, thanks.
