Adding to Cart…
Which version of DS are you using? dForce hair requires at least 4.11.
Does this product have a lay flat morph so it can also be used as a rug?
Ok, two questions on the cape... 1. Is there a way to get the fur to show up in the preview? For whatever reason I can only see it when it renders which is a little painful. I tried messing with the tesselations, but I just get little wirey hairs to show up in the prview window. 2. How do I get it to just hang off the shoulders and stop following the models arms? I just want the cape to hang off the models back, but when I make any adjustments, it follows the elbows and I can't figure out how to make it stop.
Thanks in advance!
I see my first question was answred in another thread, still messing with the shoulder issue though.
It does not, but a good idea. I will see what I can do.
Did you try the adjustment morphs under the Shaping Tab? There are morphs to move the cape off the shoulders. You would use these BEFORE you start a simulation.
Yes got it! Thanks!
