Clothes expanding to take over the scene
Hi!
I apologize if this problem has been addressed elsewhere, and my search terms weren't the right ones to find that discussion. I assure yout hat I did try.
This isn't the first time I've had this problem. A garment, conforming to a figure, expands and takes up the entire scene, sometimes propagating infitely, or sometimes just too much, like the sleeves here on Sorceress for Genesis 3 Female. It usually (but not always) occurs when I pose the figure wearing the garment. When it happens, I click the eye on the garment first, to make sure that it's the culprit. Then, I disable mesh smoothing, thinking that might be causing the issue. But it never works. When I hide the garment, and then make it reappear, it fits right for a moment, then goes back to its distorted form. I tried selecting the garment and zeroing it of all shapes, morphs, and poses, but that doesn't seem to do the trick either.
This used to happen more frequently with V4's and G1's, but I was suprised to run into it on a G3 wearing a G3 outfit. This image shows a pretty mild version of the problem. There are times where the garment literally fills the entire screen.
Does anyone have any clue what's doing this? Thanks in advance.
So this is outfits used on the figure for which they were made, no AutoFitting?
Right. It's a G3 wearing a G3. Used to happen on V4 stuff with V4's.
are you running dforce on it? I have never seen this issue unless trying to dforce and item or turinig it into dynamic
Thanks for the response.
I haven't even started messing with Dforce yet.
Hmmm, so what outfits are you having problems with?
