Weird Auto-Fit on Mac
BellaBella Posts: 447
edited August 2014 in New Users
Hello,
I've just noticed a little problem with auto-fit: there is nothing in the first drop menu...."what figure....", while the second menu is fine....
I was trying to fit a Genesis clothing on Genesis 2 Female....the weird thing is that it's happening only on my mac while it works perfectly on windows....I still can use it choosing that only option "unsupported" but it doesn't work perfectly.... anyway it seems to be installed, as you can see....what's happening?
Post edited by Bella on
  • Richard HaseltineRichard Haseltine Posts: 108,780
    Is Smart Content working on the Mac?
  • BellaBella Posts: 447
    Yes, the smart content is working but I had to fix it after I moved "My daz 3d library" folder to an external hard drive.
    It wasn't working anymore so I searched for help in the forum and I learnt how to Re-Import the Metadata...then it worked, is there something else I should do?
  • TotteTotte Posts: 14,815
    A couple of things I've seen.
    (1) Is the Genesis/G2F Autofit stuff installed?
    (2) Did you have the item selected? (I've seen it sometimes does this when the wrong item is selectec, for exasmple Autofit pants, works, but when you then add shirt, pants, not Figure is selected.
    Hi Totte,
    there should have been everything, everything I have is on win and on mac....
    Reading what you said I tried to load this lesson http://www.daz3d.com/using-auto-fit-genesis-to-genesis-2-female
    and then I've got the error I attach ...
    The funny thing is that I had those files installed.....I tried to uninstall & reinstall but the error is still there....I'm confused!
    848 x 340 - 45K
    Are they really installed to a directory that DAZ Studio has mapped to it?
    Sounds like you have not mapped the directory that things are installed in correctly.
    You got it but I swear I had done it!!....then it had somehow come back to the previous folder that is now empty....
    So....problem solved, now it works!
    Thank you very much!
