How to turn off Shadows?
I want to make this piece of geometry not cast any shadows, especially in the Filament viewport. Turning off "Cast Shadows" doesn't do anything. Is there a way to achieve this?
You can remove the object.
use 3Delight
or the Octane Render Plugin
I have to use Filament and need the object visible at all times in the scene.
In that case, you're stuck with compositing.
I thought some type of lights in Filament could have their shadow casting off? Think I had to turn them on last time I tried working with Filament.
lights in Filament can have no shadows but the HDRI will unless its strength is 0 in Filament Draw options
actually its being problem when you use clothes that have transparency like stockings.
in filament there is no shadow bias option of the lights, stocking itself casting shadow to the body. There has to be a way to disable casting shadow.
