How to turn off Shadows?
I want to make this piece of geometry not cast any shadows, especially in the Filament viewport. Turning off "Cast Shadows" doesn't do anything. Is there a way to achieve this?
  • SevrinSevrin Posts: 6,314
    You can remove the object.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,659
    use 3Delight cheeky
    or the Octane Render Plugin
  • Faux2DFaux2D Posts: 462
    I have to use Filament and need the object visible at all times in the scene.
    In that case, you're stuck with compositing.
    I thought some type of lights in Filament could have their shadow casting off? Think I had to turn them on last time I tried working with Filament.
    lights in Filament can have no shadows but the HDRI will unless its strength is 0 in Filament Draw options
  • DamnekoDamneko Posts: 10
    edited April 2021
    actually its being problem when you use clothes that have transparency like stockings.
    in filament there is no shadow bias option of the lights, stocking itself casting shadow to the body. There has to be a way to disable casting shadow.
    Post edited by Damneko on
