IrayTo3Delight conversion script
12345679»
  • stitlownstitlown Posts: 309
    Hi, Guys. Thanks for this, but some help please, as I must be as thick as two bricks, possibly even a besser-block or two. I'm trying to convert some Howie Farkes vegetation back to 3DL. I have the script. I can even read it (in Notepad++ or the IDE), not that I understand the code. I select my object, I select all the surfaces in the object and I execute the script (it takes approx 400ms), but as far as I can see nothing is changed.
    What am I not understanding???  Cheers, Lx
  • carrie58carrie58 Posts: 4,098
    edited March 2021
    Are you looking at your surface tab? I always double check and lower the"Displacement" and "Bump" maybe a before and after  screen shot would help ,
    Post edited by carrie58 on
  • I am sad this no longer appears to work, at least for me. Sad!
    edited April 2023
    How is it not working? I've found that sometimes I have to change the base mixing in the surface tab to "weighted" before the script will work
  • CriosCrios Posts: 3,001
    I'm using the script on DAZ 4.15, and still worlk. Maybe is the DAZ version the issue?
