I need a little help
I remember something where you held a key down and clicked on a line. the line was deleted and the two adjacent surfaces became one surface. I hope someone can help.
  • AscaniaAscania Posts: 1,840
    Are you talking about Target Weld?
  • GreycatGreycat Posts: 332
    no
    Then you're talking about Backspace.
    That maybe right
    nope that's not it.
    498 x 805 - 69K
    I take back, that is it. Thanks
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited March 2021
    Ascania is right, it is the Dissolve Vertices tool you used.
    Not wanting you to go to far with your model, you are going to run into problems with the approach you have taken - Ngons (Selection, Select non 4 point faces).
    I recreated your model (using quick extrude and symmetry) and took a few screen grabs.
    1918 x 976 - 612K
    Post edited by Wee Dangerous John on
