Faded Illusions earrings 8.1
DaventakiDaventaki Posts: 1,624
edited March 2021 in The Commons
Im having trouble with the wearable preset for the earrings with the Faded Illusions outfit on 8.1..  It prompts for the unsupported figure and doesn't give me a Genesis 8 Female option.  The small earrings go into place correctly but the large earrings distort when added to the scene.
Post edited by Daventaki on
  • Richard HaseltineRichard Haseltine Posts: 109,104
    The earrings preset is set to be compatible with the White Priestess ears (and indeed parts of them, the cuffs and small earrings are free-floating with the ears from White Priestess not present). If you load them, cancel the autofit dialogue, and delete the small earrings and cuffs then the large ones should fit to and work on the base figure. I would think this was worth a bug report - the preset for the large earrings, at least, should work with the base figure too (and at the moment it isn't working at all without the texture pack installed).
  • DaventakiDaventaki Posts: 1,624
    This is the White Priestess with ears applied on G8.1F.
    I tried adding them both to the ears and to the 8.1F both give the autofit dialog.  I have a render going now and haven't had time to really test thoroughly but once I have I will submit at ticket.  For my render I unparented them and manually placed the earrings.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    https://www.daz3d.com/dforce-faded-illusions-for-genesis-8-and-81-females
    Yes, these earings are problematic.  Does this need to be reported?
    Ok I submitted a ticket.  The distortion has to do with using the autofit I guess, but it doesn't give a G8F option so I just hit cancel and manually placed them.  But the seperated option for the large earrings don't work at all.  The cuffs and smaller earrings work fine.
    Ok yes I saw there was no G8F option
