Back after some months, found out about G 8.1
Plz tell me the process of converting my own G8 characters to G8.1 successfully. All morphs, textures, grafts and everything please.
  • GordigGordig Posts: 10,758
    You don't need to convert morphs or textures. I'm less certain about grafts, but since the geometry hasn't changed, I suspect those will work without issue, too. G8.1 does have a new UV, so if you wanted to convert them, you could load a G8 texture onto G8.1 and then Map Transfer to the new UV, but you wouldn't get the benefit of textures which were made for the new UV.
    how do i map transfer uvs?
    Load up G8.1 base, add a G8 texture, then follow this tutorial.
