Back after some months, found out about G 8.1
Plz tell me the process of converting my own G8 characters to G8.1 successfully. All morphs, textures, grafts and everything please.
You don't need to convert morphs or textures. I'm less certain about grafts, but since the geometry hasn't changed, I suspect those will work without issue, too. G8.1 does have a new UV, so if you wanted to convert them, you could load a G8 texture onto G8.1 and then Map Transfer to the new UV, but you wouldn't get the benefit of textures which were made for the new UV.
how do i map transfer uvs?
Load up G8.1 base, add a G8 texture, then follow this tutorial.
