"Elder Protection" Bodysuit G8/8.1F
SquishySquishy Posts: 725
A model of an unearthly bodysuit, rigged in DAZ Studio for Genesis 8/8.1 Female. 6876 polys. A good assortment of Iray materials are included, as well as some optional material files that hide or show various parts of the model.
NB: The materials make extensive use of REFLECTION, REFRACTION, TRANSPARENCY, and EMISSION. Depending on graphics hardware and settings some of these materials may not show accurately or at all in preview. Use the NVIDIA Iray preview engine for a more accurate idea of what the final render will look like.
NB: the morphs, weights and JCMs are in a "good enough" state and work fine in a big variety of poses. If you find a position or shape that makes the mesh break, try dialing up the "FBMExpandAll" morph, or the other usual methods of dealing with pokethrough etc.
https://sharecg.com/v/97277/view/21/DAZ-Studio/Elder-Protection-Bodywear-G8-8.1F
  • SeraSera Posts: 1,675
    Nice. Thank you!
  • ColemanRughColemanRugh Posts: 511
    Great design! Thanks!
  • ElorElor Posts: 4,063
    Hello,
    The Renderhub version has a small folder error (not present in the Renderosity version but according to the Readme, the Renderhub version is supposed to be an updated version):
    2025-04-26 15:15:08.308 [ERROR] :: Open File Failed - Could not read file: /data/Excessive/Bodywear/Elder Protection/Elder_7787.dsf
    2025-04-26 15:15:08.309 [ERROR] :: Open File Failed - Could not read file: /data/Excessive/Bodywear/Elder Protection/UV Sets/Excessive/Base/default.dsf
    In the Renderhub archive, instead of /data/Excessive/Bodywear/Elder Protection/, it's /data/Elder Protection/
    Creating /data/Excessive and /data/Excessive/Bodywear/ and moving Elder Protection were Daz Studio is looking for it fixed the problem, and once I did that, everything seems to work as intended.
  • SquishySquishy Posts: 725
    edited April 2025
    Where does this happen exactly, when loading the suit or loading one of the material files?
    e: Never mind I see it. I assemble the package for distribution by hand and this was just a mistake in setting up the directory, thanks for catching it.
    Updated: https://www.renderhub.com/excessive/elder-protection-bodysuit-g8f
    Post edited by Squishy on
