[Released] PARSIS: a fast particles system [commercial]
AlbertoAlberto Posts: 1,458
edited March 2021 in Daz PA Commercial Products
PARSIS is a new particles system for DAZ Studio plugin.
Parsis offers a vast world of magic visual effects. Sparks, explosions, projectiles, rays, a ring of asteroids, bubbles, falling rocks, stars...  countless possibilities, the limit is your imagination!
Its main features are:
  • Very fast simulation (PARSIS uses the ArrayFire accelerated computing library).
  • The user can use triangular billboards or any geometric objects as particles.
  • Collisions with any geometric node in a scene.
  • The sources (emitters) can be a point source, a blob, or any geometric node.
  • Forces and force fields to control the trajectories.
  • OpenCL acceleration for Windows
  • For animations and static scenes.
Compatible with Windows 64 bits and macOS 64 bits.
https://youtu.be/4n9WZyGYnIk
Some examples:
Post edited by Alberto on
«13
  • ArtiniArtini Posts: 10,426
    The example images does not show up, maybe you need to use "Attach a file" option,
    when you post a message here.
  • AlbertoAlberto Posts: 1,458
    Thank you, Artini! The images were visible in Chrome, but not in Opera.
  • GranvilleGranville Posts: 698
    So cool!
  • UthgardUthgard Posts: 880
    Finally! This could not come too soon.
    You wizard! I still like your fluidos plugin!
    edited March 2021
    Granville said:
    So cool!
    Thank you!
  • What does DAZ Studio see the particles as? Are they DAZ instances?
    There are two possible modes: one uses billboards (a geometric node constructed by the plugin). The other mode uses instances of any geometric node the user wants.
  • HylasHylas Posts: 5,256
    edited March 2021
    Looks potentially interesting, but I´m not sure I 100% understand what it does... how is it different from UltraScatter Pro?
    ETA: Watched the video... I´m guessing the main difference is that this product can be used for animation, too?
    Post edited by Hylas on
    PARSIS is a particles system, thus it's dynamic. That is, the particles change their position along time following forces and some other rules. They can increase their number and die along this time, can collision with objects and bounce or stop (see the video)
    On the other hand, Ultrascate Pro is a replicator system. It's dedicated to finely distribute instances in space, but not in time.
  • Anyone else missing the serial number for PARSIS ? Just bought it but cannot find it in my serial number list.
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    Same here. I have opened a ticket with CS.
  • UrdwolfUrdwolf Posts: 27
    Me too.  Have just put in a support request.
    Looks like I am holding out until the issue is solved!
  • SimonJMSimonJM Posts: 6,076
    Thank you to those submitting a ticket, I will ride in on your coat-tails :)
    edited March 2021
    Again and again? surprise
    Sorry about that.
    I've just reported this to the store.
  • BeeMKayBeeMKay Posts: 7,019
    No serial number here, either. But a really cool system, thank you for creating it! I can't wait to use it... tomorrow, maybe, when the serial number's showing up. :-)
    Does anyone have received a serial?
  • Richard HaseltineRichard Haseltine Posts: 108,889
    It is being worked on.
  • Charlie JudgeCharlie Judge Posts: 13,328
    How does Parsis compare to Sim Tenero's Particle Physics ?
    Just going by the description, it allows you to use whatever props you want as particles or sources, while SimTenero's product is far more restrictive and only allows you to use the included props as particles while the emitters are part of the package. SimTenero's solution has some nifty features like changing opacity or color over time, but I always found the implementation far too limiting. If PARSIS works as the promo states, it would allow you to, for instance, select a few tree branches as emitters and have them drop leaves as particles (or the proverbial sakura blossoms rain), which the previous system never allowed you to do. Personally, I am quite excited at the possibilities this opens up, and I am eager to give it a try when I get the chance.
    Just a question, Alberto, is there a way to use an image map to determine what part of an object is an emitter? I am thinking about, for instance, a plane with an opacity map where only the visible parts act as emitters. That would be great for all sorts of applications.
    Not a map, but you can use the Daz Studio's Geometry Editor Tool to select the vertices from the area you want to act as emitter. Then, the other regions of the object are ignored.
  • RandWulfRandWulf Posts: 218
    Yes - -- no serial number here either.  Waiting to see if the support ticket resolves it...
    Hi!
    They told me they're working on it.
    Just to be sure - this system is for creating, mostly, animations in Daz Studio.
    There is no use for it, when creatic static, single frame renders.
    PARSIS is useful for animations and for statics scenes either. The plugin has an option for doing the calculations for some simulation time without advancing the frames, thus generating only one frame (stabilization steps option).
    That's somehow better and worse at once. I mean, when using a 3D object it will be far more convenient to, for instance, select the geometry of a character's palms than using a map, but when trying to do a radiant magic circle you will need quite a high poly count if you want something detailed... Still, first-world problems compared to not even having the option. Any chance we could get a link to the manual while we wait for Daz to actually do their jobs?
    Takes REALLY long this time... I did not even receive an answer to my ticket yet (apart from the automated response), which is rather unusual.
    Uthgard said:
    Alberto said:
    vbb
    If you install the plugin, the manual will be inside the folder where DAZ Studio is installed, that is:  /Program Files/DAZ 3D/DAZStudio4/docs/Plugins/PARSIS A Particles System
    And, no, you don't need a very high poly count, because, in fact, the vertices are not the emitters, but it's the area they cover. You need, of course, more than a few vertices to define this area, but not too much.
  • azoohouseazoohouse Posts: 664
    The serial number just arrived!
