config error daz connect -- how do I shut it off?
alan bard newcomer
daz decided that a configuratin error had occured and I can't use daz connect unitl I re authorize or such.
I have never used connect .. doubt if I every will but can't seen to find anything in preferences
But for now every load sequence stops until I reply to the message.
An error message is fine, but as a programmer I expect the link to address the issue right there in the dialogue box.
I did shut off that first dialogue box that popped up everything you started the program to let you link to daz, which may have the link to re-connect to something that I've never used.
anyone know the magic to make the right thing appear to lock this away?
Post edited by alan bard newcomer on
I'd try to log on once in order to ensure that your settings are ok. Just click the login button on top of the smart contents pane, use the right credentials and make sure not to enable the automated logon. At the very least this should allow you to ensure that you're using the right settings, and if won't change a thing: you won't be automatically logged on.
However, just making sure: are you certain this is about Daz Connect and not, for example the cms system powered by psql?
Thank you
we'll sse what happens... I've never opened the smart content pane... never used it.. told it to login .. didn't seem to do anything but will see text time I open the program
double thanks.. just opened new instance and annoying message is gone
