Combining figures parenting posing
Have two figures, genesis 8 male, genesis 8 male metallic robot.
Combined into one , parented the robot to the figure.Parts are same
Net result is to produce image of Cyborg, Half human etc.
In theory when I move the arm on the human, the robots arm should move as well......does not
How can I setup so only one figure has to be posed?
Thank you
One needs to be Fitted to the other - if the bones are joint origins match just select the robot and use the Fit To property in Parameters.
Mr. Haseltine....once again the poets will sing your praises.
Worked great.
Thank you......once again .
William McGonagall?
William McGonagall?
Larry of the Bronx.
I came across this page becuase I have the same issue.
However When I tried the "fit to" option on my cyborg body to parent it to the human model, it just freezes at 22 percent and requires a crash and restart.
what am i doing wrong?
Which robot, which human base (Genesis or whatever), and which version of DS?
