Combining figures parenting posing
Have two figures, genesis 8 male, genesis 8 male metallic robot.
Combined into one , parented the robot to the figure.Parts are same
Net result is to produce image of Cyborg, Half human etc.
In theory when I move the arm on the human, the robots arm should move as well......does not
How can I setup so only one figure has to be posed?
Thank you
  • Richard HaseltineRichard Haseltine Posts: 111,972
    One needs to be Fitted to the other - if the bones are joint origins match just select the robot and use the Fit To property in Parameters.
  • bicc39bicc39 Posts: 589
    Mr. Haseltine....once again the poets will sing your praises.
    Worked great.
    Thank you......once again .
    William McGonagall?
    William McGonagall?
    Larry of the Bronx.
  • I came across this page becuase I have the same issue.
    However When I tried the "fit to" option on my cyborg body to parent it to the human model, it just freezes at 22 percent and requires a crash and restart.
    what am i doing wrong?
    Which robot, which human base (Genesis or whatever), and which version of DS?
