Dforce Tracy hair issue
I just bough the Dforce Tracy hair for G8F just a few minutes ago and decided to try it out because I wanted to convert it to use for my G3F figures. When I put it on a G8F figure at first though, it ended up coming out as a solid mass of one color, like in the first picture below - then when I attempted a preview render, the hair did not show up at all, only the scalp and the headband (seen in the second picture).
What can I do to fix this, because I don't want to feel like I wasted $15 on a hair prop that doesn't look right and won't show up in renders?
    if it's strand based hair, it doesn't usually show up by default in the iray preview window. You usualkly have to increase the tesselation in the settings to get it to show. try a regular render and see if it shows.
  • Just did a test render and it showed (below).  Thanks about how these newer hairs work, I just thought at first there might have been something wrong with the prop.  yes
    1113 x 1042 - 299K
