How do I undo the hair deformation?
Ascania
I'm hit with the stupid right now and can't remember how to resolve this issue, so please help?
On Genesis 8 when using the Growing Up morphs the hair "tucks in" around the neck. How do I get it to hang straight again? Hair in the attached image is Andria Hair but it happens to any hair hanging low enough.
in the hair parameters
show hidden set to zero the trasferred morph who causes the deformation
not sure if this will work on a FBM who affect the height
a more articulated way is to duplicate unfit/unparent the hair, move and resize the copy the more similar to the fitted one (you can parent it not in place, then move on y axis, and you can get some scales, not always working)
export as obj with zero subd, import as morph with reverse deformation on the fitted hair
Thank you.
