How do I undo the hair deformation?
Ascania
I'm hit with the stupid right now and can't remember how to resolve this issue, so please help?
On Genesis 8 when using the Growing Up morphs the hair "tucks in" around the neck. How do I get it to hang straight again? Hair in the attached image is Andria Hair but it happens to any hair hanging low enough.
500 x 650 - 29K
in the hair parameters
show hidden set to zero the trasferred morph who causes the deformation
not sure if this will work on a FBM who affect the height
a more articulated way is to duplicate unfit/unparent the hair, move and resize the copy the more similar to the fitted one (you can parent it not in place, then move on y axis, and you can get some scales, not always working)
export as obj with zero subd, import as morph with reverse deformation on the fitted hair
Thank you.
