Daz Website DNS Error
Anyone else getting this.
I cannot down load a thing from the Daz website as I keep getting a DNS 1016 Cloud fare error.
My project is currently halted due to an internet glitch. Tried other sites and no issues there...
Steve C
  • Connect is working, I haven't tried DIM/Daz central, but yes the product Library is doing that - I will report. In the meantime, even if you want to do manual installs you could try using Install Manager as a downloader.
  • Yeah same.
    I keep getting download failed with dim, so I tried a manual install and got Error 1016 Origin DNS error
  • DAZ_RawbDAZ_Rawb Posts: 817
    Seems like a cloudflare glitch in their DNS handling. They are generally pretty quick about resolving this sort of issue, but I'll keep an eye on it.
  • ShelLuserShelLuser Posts: 749
    edited February 2021
    I think the problem runs much deeper; I was about to post a question if people had a maximum download limit per day because I too am experiencing issues. And with DIM out of all things...  then I saw this thread.
    I bought myself some huge packages today: 11Gb+ download in total, everything went fine when all of a suddem wham... nothing. "Download Failed!", and I'm quite unhappy with this because this manifested itself during a download. I already got around 5Gb but...   waiting for Neo City; it grabbed parts 1 and 6 but 2 - 5 completely refuse to download all of a sudden.
    This definitely looks like a problem with the Daz servers.
    (edit)
    In the mean time I did some checks of my own and for sure...
    ;; OPT PSEUDOSECTION:; EDNS: version: 0, flags:; udp: 1280;; QUESTION SECTION:;daz3d.com.                     IN      A;; ANSWER SECTION:daz3d.com.              300     IN      A       104.18.222.105daz3d.com.              300     IN      A       104.18.221.105;; Query time: 7 msec;; SERVER: 195.8.195.8#53(195.8.195.8);; WHEN: Sat Feb 13 00:04:10 CET 2021;; MSG SIZE  rcvd: 70peter@vps:/home/peter $ dig @104.18.221.105 sdn.daz3d.com; <<>> DiG 9.16.11 <<>> @104.18.221.105 sdn.daz3d.com; (1 server found);; global options: +cmd;; connection timed out; no servers could be reachedpeter@vps:/home/peter $ dig @104.18.222.105 sdn.daz3d.com; <<>> DiG 9.16.11 <<>> @104.18.222.105 sdn.daz3d.com; (1 server found);; global options: +cmd;; connection timed out; no servers could be reached
    Kinda weird for 2 DNS servers to go out at once, I sure hope this isn't a single server which just so happens to have 2 IP addresses (as is a common practice with some hosting companies).  Wait...  seems that netblock is hosted by Cloudfare as well, meaning that I was using a proxy. Even so... the issue seems clear enough.
    (edit2)
    I made a doodoo up there: I meant to use dig @...  NS, not the stuff I did up there. Even so, the result is still somewhat the same because according to Cloudfare "cdn.daz3d.com" uses those two IP addresses I mentioned above as well. But my comment about 2 DNS servers going out at once is bogus. Blame my Fridayevening beverage :)  Can't edit that code window so I won't.
    Post edited by ShelLuser on
  • memcneil70memcneil70 Posts: 6,160
    Yeah, I have 1.something Tb download per month and have only just now turned on DS and DIM. Only did a few things online today. I am okay with waiting, but will be careful about uninstalling and reinstalling products where I have problems in Lost and Found from my User Data Reset.
  • I was downloading manually OK until about 3:00pm Pacific Time when one had a DNS error. Then one DL'd, but a couple of minutes later nothing would download.
    No, you picked that up wrong (or maybe I didn't explain correctly): I wasn't referring to client bandwith but possible throttles on the Daz servers to prevent clients from downloading too much data at once. That's also a practice you sometimes see with some servers in order to try and spread the bandwith a little.
    That shouldn't matter too much, Lost and Found is also often used when you're installing perfectly normal items through DIM.  Right now I got parts from the industrial bedroom, open apartment, tooth and bone (savage acc. for gen2) and some pharao stuff for V4 in there. Although I have re-catagorized quite a bit I only add categories and never removed them (definitely no 'base' categories so to speak).
    Sometimes I want to... for example "Environments" vs. "Sets" which are roughly the same thing where "Architecture" is concenred, but oh well ;)
  • The issue seems to have been resolved; my download just kicked in again and I'm >< close to finally strawl around Neo City!
  • AllenArtAllenArt Posts: 7,176
    Not sure if this is related, but his site has been SLOWER THAN SLOW for me the past weeks. I almost keeps me from coming here and some days, I haven't. It's so frustrating, especially after the whole Storepocalypse.
    Laurie
  • IceCrMnIceCrMn Posts: 2,334
    was just using DIM to look at some installed files and I got this
    504 x 143 - 21K
    Post edited by IceCrMn on
  • akmerlowakmerlow Posts: 1,124
    Happened to me several times as well lately, including when was downloading purchases.
    Post edited by akmerlow on
  • reelyorreelyor Posts: 237
    I hAD SIMILAR PROBLEMS, AND ALSO WITH dim. i REINSTALLED dim AND IT WORKED RIGHT AWAY.
  • Well it's happening again. Error 1016, all that. Bought a couple of things and I can't download them.
    The web team is aware, so with luck it will be fixed soon.
  • mcorrmcorr Posts: 1,105
    about two hours of downtime
    Post edited by mcorr on
  • Well, there was a reason why we switched from cloudflare to AWS....
  • Error 1016
    Ray ID: 62323398a696bbdc • 2021-02-17 20:19:08 UTC
    Origin DNS error
  • I can use DIm again, so error seems to be fixed for that part, at least.
