Updating To Genesis 8.1 On Older Scenes
Does Anyone Know If It's Possible To Update Genesis female 8 To 8.1 On An Older Scene That Was Saved With Genesis 8 Before 8.1 Came out?
Loading Character Preset Only Adds A Character It Does Not Give You The Option To Update The Character.
I Want To Be Able To Redo Existing Scenes With The New Improved Figure As Opposed To Just Creating A New Scene
It Seems The Figure Naming Algorithm Makes This Impossible.
Any Suggestions?
    Well you could just save the material as a preset and the pose as a preset and then delete the figure and then add the 8.1 and apply the pose and material. It's what i do for G3 to G8 scenes.
    I haven't tried this, but if the scene is not too big, you should be able to open the file in Notepad++, search for "Genesis" and edit the references to point to corresponding Genesis 8.1 references - Save the file and when you open it in DS 4.15 you have exactly the same scene, but the base character is now Genesis 8.1 instead of Genesis 8.0
  • Ghosty12Ghosty12 Posts: 2,093
    edited February 2021
    I had a look at one of my files and it would be very time consuming to edit, not forgetting that the files are compressed..  What FSMCDesigns suggests would be a lot quicker, and have a lot less chance of things going wrong..
    Post edited by Ghosty12 on
  • nicsttnicstt Posts: 11,715
    I set up a couple of so G8.1 figures, with the shaders as i want; I have V8.1 eyes and mouth textures included. Set up anything else on the figure you do as a regular thing and save as a subset.
    That way you have a G8.1 ready to go, all you do then is get the textures and shape. I have zero interest in replicating the shaders from G8, ymmv.
    Post edited by nicstt on
