M4 available morph packs
themarkcymruthemarkcymru Posts: 86
edited December 1969 in Poser Discussion
I'm looking for a Michael 4 leg lengths morph?
Any suggestions?
  • Richard HaseltineRichard Haseltine Posts: 108,781
    Morphs++ has a leg length control, though I can't recall how well it works in Poser.
    I think that and arm length will not work in Poser due to the tri-axis scaling.
  • themarkcymruthemarkcymru Posts: 86
    Thanks Richard, I have Morphs++ but just couldn't find leg length. I'll take another look.
    Male-M3dia - please don't say that. That would just blow my plans out of the water. So if there is an issue (haven't tried it yet) is there an alternative?
  • ByrdieByrdie Posts: 1,783
    edited February 2015
    Maybe not in older versions but I have gotten it to work in PoserPro 2014 with the latest SR. Here it is set to 1.00, so far I am not seeing any borkage. Unlike in Poser 8 & 9, where the scaling did tend to screw up often.
    Adding: Hand, palm, chest and head size morphs also work just fine in Poser now. But I have not found anything to change the length of the arms, unfortunately. And if you don't have PoserPro, this also works in Poser 10, just make sure it's up to date.
    500 x 457 - 12K
    Post edited by Byrdie on
    Did you run the morph though different poses? I recall the arm length causes a break between the shoulder and upper arm, and there was a thread where someone tried the leg morph and the mesh broke above the knee.
  • WandWWandW Posts: 2,901
    Single-Axis scaling was added in Poser 9 SR2, IIRC and the Morphs ++ leg length Morphform works fine in Poser 9 and higher.
    This Morphform is actually not a morph, but an ERC that controls the y-scale of the thigh and shin actors, so you can also simply adjust the y scale of the thigh and shin actors (or shoulder and forearm for the arms) manually ; you will need to unhide the dials for this, as DAZ hid them. This free script will do it...
    http://d3d.sesseler.de/index.php?software=poserpython&product=unhide_dials
    Here's a quick render with legs length at -1. It works fine at +1 too...
    480 x 600 - 13K
    The legs appear okay in these poses though the last (squat) does look a bit wonky near the tops of the thighs/butt. Which could be the morph but may also be normal in an unfixed M4 -- here I've only loaded the base and Morphs++, none of the bend fixes I usually use on him.
    There's an arms length morph? Where? So far I've only seen head, chest, hands, palms and feet size dials, other than the legs length. Must be in some other pack.
    500 x 457 - 10K
    500 x 457 - 12K
    500 x 457 - 11K
    This is all great news guys, thanks.
    WandW. - where did you find the arm length morph?
    EDIT - Sorry WandW, just spotted your link for free script. Thanks!
    Post edited by themarkcymru on
    Gah! I forgot about that script. Thanks for the link, will certainly come in handy. :-)
    With PP2014, you don't need it; just tick "Show Hidden Parameters" on the menu you get by clicking thelittle arrow at the top right of the Parameters Pane... :)
    Even better. Thanks! :-)
    I still can't find arms length?
    There isn't an arms length morphform per se. You need to unhide the y-scale dials for the shoulder and forearm actors and adjust them as desired...
    Sorry for being so dumb WandW how would you go about unhiding the y-scale dials for the shoulder and forearm actors?
    After installing the script (the directions are in the readme file to add it to the scripts menu) that I linked to above, you would select the body part, run the script and select "yscale" to unhide. If you unhide the dials and save it to the Figures library under a new nake, you can load it up in the future as needed.
    PS the only dumb question is the one unasked... :)
    Thanks WandW you are a STAR
    Doesn't look like the script is compatible with OSX. I might look to creating my own morph for arms length.
    That's unfortunate. Give this a try. It's for V4, but she has the same bones as M4...
    http://www.sharecg.com/v/34020/browse/11/Poser/Show-Scale-Dials-V4-ScaleShowAllV4.pz2
    Thanks again WandW. That seems to do the job just fine. Like I said you're a STAR!!!
  • Does anyone know of M4 tongue morphs?
    edited March 2021
    This sadly no longer seems to be avalilable...
    https://www.renderosity.com/rr/mod/bcs/sexy-tongue-ii-for-m4-stand-alone-version/67894
    EDIT; the V4 version might be able to be used; it's at Poser Addicts...
    http://shop.poseraddicts.com/index.php?act=viewProd&productId=130
    There is a repacement tongue by Darkseal at Renderotica, but I've no experience with it...
    Post edited by WandW on
