DELETE
davesodaveso Posts: 8,397
edited October 2021 in The Commons
DELETE
Post edited by daveso on
  • SorelSorel Posts: 1,440
    use a cube instead.
  • glaseyeglaseye Posts: 1,312
    AFAIK, a primitive plane is 2 dimensional, so no, it can not be "thickened". But maybe you could use a cube and "flatten" that; that's what I do when I need a simple 3d wall. Or if it  is about texturing, then maybe use several 'planes' to make a wall; that way you can easily apply a texture to the large "side(s)" of the wall.
  • davesodaveso Posts: 8,397
    edited October 2021
    DELETE
  • daveso said:
     enlightened use a cube enlightened ... as I slap myself along the side of the head . DUH.... wow, I need sleep.
     In other words... you need to think in to the box, not out of it.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,852
    like a cat
  • FSMCDesignsFSMCDesigns Posts: 12,859
    LMAO, we've all been there.
  • jjmainorjjmainor Posts: 501
    If you had Hexagon, you could send the plane to Hexagon, use the thickness function, and bam.  But yeah, I'd probably just reshape a cube.
  • NathNath Posts: 3,069
    Solidify in Blender would work as well I think. But yeah, use the Cube, Luke!
    (and we've all been either there or in similar 'duh' positions laugh )
  • DripDrip Posts: 1,277
    You could also try to mess around with a normal map to "lower" the edge with a short gradient, making the plane appear to curve down there. It's a trick designers sometimes use when they make holes in thin items (like clothing) using opacity maps: they match the holes with a normal map.
  • pro tip
    I edit my primitives with the geometry editor so if you ever need a circular plane, delete half a sphere and scale it to 0 on the y axis
  • LinwellyLinwelly Posts: 6,070
    WendyLuvsCatz said:
    pro tip
    you could just flatten a cylinder to y0
    edited February 2021
    Linwelly said:
    WendyLuvsCatz said:
    pro tip
    true or the sphere for that matter cheeky
    but for a single side a cylinder just keeping one end may be better depending on how you want the topology
    I prefer the edgeloops on a sphere
  • TaozTaoz Posts: 10,384
    You could stack some planes cheeky
    cheeky
    You are evil.
    one could also use a plane for one side of the surface, then create another plane & rotate it so that it becomes another surface, and keep repeating this process until one builds a 3-dimensional equivalent of a plane.
    coolwink
    Actually, sometimes I prefer to do this when I'm dropping certain patterns or opacity maps onto the primitive. It doesn't always map well onto a cube for the thing I'm intending to use it for.
  • marblemarble Posts: 7,500
    I'm loving this. The number of times I have asked a question and then realised, too late, that it was a Doh! moment ... just good to know that others do it too. Even with the OP,  my first reaction was "oh, good question" but then it dawned on me before I carried on reading.
    Post edited by marble on
  • mmalbertmmalbert Posts: 412
    I needed 60s style furniture pieces a couple years back. It can be hard to find that sort of specific style, so I used photo references and primitives to make this set. Rendering with DOF is very forgiving. :)
    Mostly cubes and cylindars, but also the torus (feet on the table legs), spheres for the clock, and cones for the clock hands. It's not functional -- no actual drawers that open -- but I only needed it for the period feel.
    A little psyllium fiber may do the trick...
    edited October 2021
    DELETE
  • ArtiniArtini Posts: 11,043
    Cylinder with 4 sides will do. Using this trick quite often, but with more sides, if I need a thickness.
