how do I turn on the humpty body PLEASE THANK YOU (BLESS YOU)
I did it once
and can't find where you do it
can someone snapshot a window shot of WHERE IT IS (please thnk you - you will be blessed)
I have created an awesome funny mini humpty
and need the body back
thank you
  • Parameters(tab)>Display>Visible in viewport
    Set this to on.
    Alternatively.
    Select the nodes with the closed eye symbol, and click the eye symbol(to open), in the Scene tab
  • edited November 2021
    how do I turn [the humpty dumpty body] it on please thanl you
    Edited for Please put your question in the post body and the title - Daz 3D Forums
  • This https://www.daz3d.com/humpty-for-genesis-8-male ? It has a fairly normal body as far as I can see, the ehad is the most dramatic difference - is that working?
  • If you're still around (lolol - a year later)
    I've had to reinstall - came back here - and I matched and did what you said.
    and the body - is not appearing.  the eyes are on the body.
    any thoughts on what I'm doing wrong?  Please thanks
    1939 x 1081 - 254K
  • I know I'm missing something obvious in turning on the body
    PLEASE - if anyone see's where I screwed up - let me know I need the body on asap.
    thanks
    Mack
    1939 x 1081 - 254K
  • Threads merged.
    You are currently using the Filament Drawstyle in the Viewport - what happens if you try a different Drawstyle, or if you render?
  • Richard HaseltineRichard Haseltine Posts: 109,378
    And another thread merge.
    Having seen the imaeg and had a look at the product page, there is "One Head Geograft to hide the body" - that is, an additional element that hides the body and, I assume, caps the neck opening. You probably have that loaded - delete it from the scene (it's probably a child of the Humpty node in the Scene pane)..
  • heres a draw style change - no body
    I can turn the body graft off - but not delete - without deleting the head
  • at one time - I thought there was something in the render settings I 'turned on' but I haven't found anything that turns the body on -
    And or there is some slider I am missing but I don't know where . :(
    1927 x 1035 - 212K
  • You need to delete the graft or set it to be Fit To None - hiding it doesn't turn the mesh-hiding off.
  • AAAAAAAAAAAHMEN!!!!!!! THAT DID IT!
    thanks so much - he's an evild demon who posses a bad guy - and they look like mini me w similar outfits lololol
  • almost upong render
    the body parts glow - something else needs to be clicked
    1818 x 1015 - 227K
    1715 x 973 - 316K
  • Those would be surface settings, I don't know which presets might adjust them.
