Daz/Blender Bridge - Two-Way? What About Rigged Figures?
Okay. I've been experimenting more with Blender recently, so I have a question about the DAZ/Blender bridge. First, is it possible to export something from Blender back into DAZ3D? Because when I tried working with Blender, I couldn't figure out how. And if a figure is rigged in Blender and I export it to DAZ, will it still be rigged or will I have to start from scratch?
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Nope, one way to blender. You can always import .OBJs into DS with no issues, bridge or not. Rigging is pretty much proprietary in DS, so anything you bring in will need to be rerigged.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,072
    not strictly true
    Poser legacy rigging works in DAZ studio
    Poser11+ can import FBX
    saved as a cr2 loaded and converted to DAZ weightmapping in D|S most stuff works
    thanks Wendy. I always forget about the poser route since I haven't had it installed in forever.
  • WendyLuvsCatz said:
    not strictly true
    Wait a minute...Poser can import FBX format and then save it as a cr2?
    edited January 2021
    OrionPax09 said:
    WendyLuvsCatz said:
    not strictly true
    yes
    not all FBX files are equal though
    Makehuman for example doesn't work
    Mixamo rigged stuff and iClone exports are generally good, they are broken into conforming parts usually
    it varies a bit
    animation needs to be saved as a pz2 and BVH works pretty well on the result in DAZ studio too
  • Alot of bones don't follow the mesh when porting to blender now, not to mention they aren't aligned correctly in the hands or really the entire upper body. Not sure what went wrong with this new update, but it has a truck load of problems.
