Adding to Cart…
LOL, nah. I see ya. And making clothes and hair fit is the easiest of easy fixes ;). People just aren't reading. I guess that's why I see the same persons over and over complaining that nothing is compatible with 8.1 when so many are saying everything except expressions is. LOL
I combined V8.1 with an imported V7, even Gia 8, and everything worked out magnificently!
you are not but since there are no 8.1 only clothes yet we haven't reached that mountain
I have 231 pages in my product library which is not insignificant and do indeed use workarounds to use almost everything on any figure in any software
so nothing new
I rarely buy converters
I can likely get those morphs working too with some effort
but others will have to spend up new as some cannot even import and obj in my experience so I am a bit cynical as to the real benefits
DAZ is a business it will be beneficial to them
I've stopped using it on 8.1; i like how they look, and can get very similar look to AGA2; I posted an image a few posts above yours on 16
I agree, much better.
It’s just another time consuming fix. I have enough clothes anyway but always looking for more hair...
deleted
1 You load the clothing into the scene but not on the figure.
2 select it.
3. Right click scene tab>edit
4. Change Scene Identification
5. Choose a different base
6. Then autofit as usual.
I don’t even have Genesis 8.1. I just downloaded the new package from DIM and have Genesis 8 Basic Female and Genesis 8 Female Dev Load INSIDE Genesis 8 MALE Powerpose Templates. Where IS 8.1?
Click on Genesis 8 Female folder in Content Library and she is an actor alongside G8F.
There is no Genesis 8 Female folder since I updated. The figures are under Male Powepose and G8 female only.
There is no reason for clothing or hair or poses (excepting expressions) to not be compatible. They use the same exact rigging.
Ok I unstalled andreinstalled but G8.1 Female is still inside Genesis 8 MALE Powerpose templates
@Wonderland this is one that I did with Victoria 8.1 plus a bit of Keyanna and Carra , both G8
https://www.daz3d.com/forums/discussion/comment/6418071/#Comment_6418071
In case anybody is interested, here is a side-by-side comparison of a franken-skin I put together (mostly Babina 8)(I only updated the head, so please ignore any funk in the neck on the right) -
And here is the HDRI I used in case anybody wants to replicate the lighting - https://hdrihaven.com/hdri/?h=studio_small_03
weirdly my Genesis 8 female and Genesis 8.1 female show up for me in Smart Content under Genesis 8 male Powerpose Templates.
But Genesis 8.1 female still shows up where it should in the normal content browser, which is under People>Genesis 8 Female
Digging the new skin shader but where's Cutout Opacity? C'mon.
Whoa! It seems I may have complained prematurely. So far all the paid expressions I bought ARE working! And I do still have visemes. This is weird...
Aha, so that's where they are! I posted above that I didn't seem to have them at all, but mine are in the same place as yours.
I gather that DS can distinguish - if the product is set up for it to do so.
did you buy the third party ones by some chance?
https://www.daz3d.com/hd-visemes-for-genesis-8-female
they indeed would work as HD morphs
Oh my, you're right! There's no opacity channel.
The only use-case i have for opacity is when using a geoshell. I guess they will have to use the iray uber.
I have that product, but the menu heading "Visemes" is empty.
I think Dawnblade is looking in the Content Library under Daz Studio Formats while you are using one of the category views. The bad categorisation is apparently known and being worked on.
I had to install mine manually. I figured it was just easier to take the path of least resistance.
Yes, you do.
So far every paid expression I tried does work! I haven't tried them alone to see if they are exactly as they should be since I combine them in increments anyway. But so far, they all do something! And visemes are still there and work...
This is crazy, everything works!
This.
This has been said SOO many times, and it needs to be stressed. Too many people are getting the wrong idea that all their G8F stuff is obsolete, and it's not.
