Ultimate Zero Scripts from RiverSoft Art suddenly stopped working
Hello together,
and another time Daz3D drives me crazy !  So after i bought some new content and installed them, suddenly the "Ultimate Zero" Scripts don´t work any longer. After the still not solved "Genesis 8 female" problem (loading time 30 to 40 Minutes) this finally drives me nuts !
Well i allready tired some things, i found here in the forum:
So i deleted the "Ultimate Zero" content manually and with DIM and installed them again: Still not working ! I uninstalled Daz3D Studio and installed it new: Still not working. I tried the way, LX75 was able to solve his problem: Still not working here.
(https://www.daz3d.com/forums/discussion/374766/cannot-run-scripts-from-riversoft-problem-solved)
Has somebody an idear, what could be the reason and what i could still try ?!?
Log-Editor:
<anonymous>()@E:/DAZ 3D/Daz3d Content/data/RiverSoft Art/Common/RSZeroConstants.dsa:33
2021-01-21 14:49:37.383 DEBUG: Error executing E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/Ultimate Zero Selected.dse
2021-01-21 14:49:37.384 Script executed successfully: E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/ultimate zero expression.dsa
2021-01-21 14:49:37.541 Loading script: E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/ultimate zero expression.dsa
2021-01-21 14:49:37.551 DEBUG: <Settings> <Setting Type="String" Key="Title">ultimate zero expression</Setting> <Setting Type="Bool" Key="Recursive">yes</Setting> <Setting Type="String" Key="Body Part">Expression</Setting></Settings>
2021-01-21 14:49:37.569 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rsconstants.dsa.enc
2021-01-21 14:49:37.577 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rsbuildpanels.dsa.enc
2021-01-21 14:49:37.587 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rshelperfunctions.dse.enc
2021-01-21 14:49:37.591 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rs2019helperfunctions.dse.enc
2021-01-21 14:49:37.597 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rs2020helperfunctions.dse.enc
2021-01-21 14:49:37.601 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/RiverSoft Art/Common/RSZeroConstants.dsa
2021-01-21 14:49:37.619 WARNING: Script Error: Line 33
2021-01-21 14:49:37.619 WARNING: ReferenceError: Can't find variable: iAbdomen
2021-01-21 14:49:37.619 WARNING: Stack Trace:
2021-01-21 14:49:37.619 DEBUG: Error executing E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/Ultimate Zero Selected.dse
2021-01-21 14:49:37.620 Script executed successfully: E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/ultimate zero expression.dsa
2021-01-21 14:49:37.964 Loading script: E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/ultimate zero expression.dsa
2021-01-21 14:49:37.978 DEBUG: <Settings> <Setting Type="String" Key="Title">ultimate zero expression</Setting> <Setting Type="Bool" Key="Recursive">yes</Setting> <Setting Type="String" Key="Body Part">Expression</Setting></Settings>
2021-01-21 14:49:38.001 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rsconstants.dsa.enc
2021-01-21 14:49:38.009 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rsbuildpanels.dsa.enc
2021-01-21 14:49:38.016 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rshelperfunctions.dse.enc
2021-01-21 14:49:38.021 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rs2019helperfunctions.dse.enc
2021-01-21 14:49:38.027 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/cloud/1_80203/data/riversoft art/common/rs2020helperfunctions.dse.enc
2021-01-21 14:49:38.033 DEBUG: Found: E:/DAZ 3D/Daz3d Content/data/RiverSoft Art/Common/RSZeroConstants.dsa
2021-01-21 14:49:38.072 WARNING: Script Error: Line 33
2021-01-21 14:49:38.072 WARNING: ReferenceError: Can't find variable: iAbdomen
2021-01-21 14:49:38.072 WARNING: Stack Trace:
2021-01-21 14:49:38.073 DEBUG: Error executing E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/Ultimate Zero Selected.dse
2021-01-21 14:49:38.073 Script executed successfully: E:/DAZ 3D/Daz3d Content/scripts/riversoft art/ultimate zero/ultimate zero expression.dsa
2021-01-21 15:01:20.048 Loaded image Z WAF Pouting.png
2021-01-21 15:01:20.050 Loaded image Z WAF Pouting.png
2021-01-21 15:01:20.053 Loaded image Z WAF Pouting Smile.png
2021-01-21 15:01:20.055 Loaded image Z WAF Pouting Smile.png
2021-01-21 15:01:20.057 Loaded image Z WAF Seductive Smile.png
2021-01-21 15:01:20.060 Loaded image Z WAF Seductive Smile.png
2021-01-21 15:01:20.062 Loaded image Z WAF Sexy Smile.png
2021-01-21 15:01:20.064 Loaded image Z WAF Sexy Smile.png
2021-01-21 15:01:20.066 Loaded image Z WAF Sexy Smoulder.png
2021-01-21 15:01:20.067 Loaded image Z WAF Sexy Smoulder.png
2021-01-21 15:01:20.069 Loaded image Z WAF Sexy Tease.png
2021-01-21 15:01:20.071 Loaded image Z WAF Sexy Tease.png
2021-01-21 15:01:20.074 Loaded image Z WAF Sexy Wink.png
2021-01-21 15:01:20.075 Loaded image Z WAF Sexy Wink.png
  • Thanks Sevrin !
    Unfortunally the commercial don´t give any help to solve my problem. Well i bought the "Ultimate Zero" Content back then when it was in the Daz3d Shop and till last week i was really totally happy with it ! Specially because it was an easy way to set things back to zero. But now and suddenly from one day to another the scripts don´t work any longer. Like i wrote before, Daz3D drives me nuts with this things. Specially because, this kind of bug or error shouldn´t be in a programm like Daz.
    But  the Commercial thread,  posted and monitored by the PA  is the ultimate source of information about the product.
    Ask the creator a question,  and you will get an response.   This PA is very proactive.
  • SevrinSevrin Posts: 6,314
    ulrichmschaefer said:
    Thanks Sevrin !
    Is the character you are trying to use this with a Genesis 8.1 character?  Most scripts need to be updated to accommodate the new character.
    The 'cloud' in several of the errors meant you installed it from within Studio with Connect at some point.  Uninstall with Connect and use DIM to install.
  • Okay, tried to solve the problem with uninstall "Ultimate Zero" with connect and install with DIM again ! Unfortunally this didn´t help too. Anyway thanks for the suggestion. Sevrin about your question: Well it´s a Genesis 3 female character. To tell the truth i mostly and only work with Genesis 3, specially because Genesis 8 cause some problem. So Genesis 8 female Character took about 30 to 40 Minutes to load. Genesis 8 male is with 5 Minutes a little or much better. Because i mostly work with Genesis 3 this new problem or bugs really drives me crazy. So till last week, the scipts worked perfectly !
  • Hooray, i think i finally found the error ! So probably the Error Source was "MARSA Elements", which is from RiverSoft Art too. So both programs use some same files, but i installed them on different harddrives. So this was probably one problem. And a second, because i installed them manually. So just i deleted them manually and now doing an update on my content. After this i will reinstall "Ultimate Zero" and "MARSA Elements" using DIM on the same harddrive. Probably this will solve the problem. At last i hope so !
