MARSA Elements {Commercial}
2
  • Artini said:
    More fun, this time with MARSA Snow Patchy and UltraScenery.
    Little island in the winter.
    That is a very pretty image.
  • ArtiniArtini Posts: 10,847
    Thanks a lot, RiverSoftArt.
  • Just bought this product, and although I'm excited to use it, I can't get the script to work at all. Just comes up with an error when I select a prop and click on the "Install Custom MARSA Elements Actions". Tried uninstalling / reinstalling the product, manually installing it, and still nothing. Shaders all functioning just fine though.
    Certainly could be something I'm doing wrong, but I can't figure it out. Is there a trick to using the script, or am I just experiencing an abnormality?
    Sorry for the inconvenience.  I would have to see the log to know.  Are you PC or Mac?
    The shader scripts (i.e., Scripts/RiverSoft Art/MARSA Elements/MARSA Snow.dse, etc) do not need to be installed in the action menu to work though.  If the "Install Custom MARSA Elements Actions" doesn't work, you can always right click the scripts and create custom action.
  • Holy crap, thanks for the quick response! Here is the log:
    2021-01-26 18:37:56.865 Loading script: C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa.enc
    2021-01-26 18:37:56.878 DEBUG: install custom marsa elements actions.dsa
    2021-01-26 18:37:56.878 DEBUG: Fa&vorites/MARSA Elements
    2021-01-26 18:37:56.878 DEBUG: C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203/scripts/riversoft art/marsa elements/%1.dsa
    2021-01-26 18:37:56.878 DEBUG: C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203/scripts/riversoft art/marsa elements/%1.png
    2021-01-26 18:37:56.884 WARNING: Script Error: Line 98
    2021-01-26 18:37:56.884 WARNING: ReferenceError: Can't find variable: InputQuery
    2021-01-26 18:37:56.884 WARNING: Stack Trace:
        <anonymous>()@C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa.enc:98
    2021-01-26 18:37:56.885 Error in script execution: C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa.enc
    The InputQuery function is in RSAdvHelperFunctions.dse.  It looks like the script is not finding that file (should be in data/RiverSoft Art/Common).  Do you have it?  Is it in the zip?  It should be.  It is on my end.  You might try uninstalling from Daz Connect, deleting the C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203 directory, and installing through DIM.
  • PlatinumPPlatinumP Posts: 10
    edited January 2021
    Ok. I uninstalled MARSA Elements from my Smart Content Library, and deleted the folder C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80203.  It's still manually installed (and still not working) in my Content Library however. I checked and confirmed that RSAdvHelperFunctions.dse is there in my Content Library, as well as the ZIP folder I downloaded everything in to manually install it.
    Tried installing through the DIM, and still no luck unfortunately. Log file shows:
    2021-01-26 19:23:39.366 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
    2021-01-26 19:23:39.371 WARNING: Script Error: Line 1
    2021-01-26 19:23:39.371 WARNING: ReferenceError: Can't find variable: Î
    2021-01-26 19:23:39.371 WARNING: Stack Trace:
        <anonymous>()@C:/Users/myname/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_56309/data/riversoft art/common/rsconstants.dsa:1
    2021-01-26 19:23:39.371 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
    Curiously, 1_56309 appears to be the G8 -> G3 clothing converter. Not sure if that helps or just makes things more confusing.
    Post edited by PlatinumP on
  • barbultbarbult Posts: 27,375
    Scripts often have problems if they are installed with Daz Connect. It looks like you have some RiverSoftArt products (SKU 56309) installed with Daz Connect and some (MARSA Elements) installed with DIM. That could very likely cause an issue. You may even have some installed with both, in which case, Daz Studio will use the Daz Connect version.
    edited January 2021
    Ok. Going to try uninstalling and reinstalling both through the DIM
    Edit: OK! I went through my library and uninstalled everything I own from RiversoftArt (which was more than I realized!), then reinstalled all of them using the DIM, starting with MARSA Elements. Aaaaaaand, it's working! It did indeed appear to be a problem with my haphazard way of installing some products through DIM, and others inside the Daz program itself. With them all consistent across the board, everything is in order.
    Thank you both for all of your help, and thank you RiversoftArt for making some great products. Sorry to hijack your advert thread for some IT help!
    Not at all.  This is my official support thread!  I am glad you got it working (and thank you for your help @Barbult)
  • XenomorphineXenomorphine Posts: 2,421
    edited February 2021
    I've tried clicking on all the scripts, but just get, "An error occured while reading the file, see the log file for more details." But doesn't point me to where this "log file" is.
    So, I uninstalled from Connect and reinstalled with DIM.
    I selected the install elements' thing, upon which point it included a spelling error and prompted me to install it to the following sub-menu: "Fa&vorites/MARSA Elements"
    I corrected the spelling error and received the same message as above: "An error occured while reading the file, see the log file for more details."
    OK, so... I tried, again. This time, figuring that maybe it somehow isn't a spelling error and allowed it to install to the default sub-menu, but received the same prompt.
    Post edited by Xenomorphine on
    Daz Log is available from Help->Troubleshooting->View Log File
  • It's like reading an alien language to me. :)
    2021-02-03 20:54:29.507 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/shader presets/marshian/marsa elements shaders/marsa !info.dsa
    2021-02-03 20:54:32.774 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/shader presets/marshian/marsa elements shaders/marsa !info.dsa
    2021-02-03 20:54:36.643 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
    2021-02-03 20:54:36.907 DEBUG: install custom marsa elements actions
    2021-02-03 20:54:36.908 DEBUG: Fa&vorites/MARSA Elements
    2021-02-03 20:54:36.908 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/%1.dsa
    2021-02-03 20:54:36.908 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/%1.png
    2021-02-03 20:54:45.146 WARNING: Script Error: Line 153
    2021-02-03 20:54:45.147 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:54:45.147 WARNING: Stack Trace:
        <anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa:153
    2021-02-03 20:54:45.149 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
    2021-02-03 20:55:07.219 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:07.239 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa mud</Setting> <Setting Type="String" Key="Cover">mud</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:07.322 WARNING: QString::arg: Argument missing: marsa mud, mud
    2021-02-03 20:55:07.330 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dse
    2021-02-03 20:55:07.331 WARNING: Script Error: Line 282
    2021-02-03 20:55:07.331 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:07.331 WARNING: Stack Trace:
        <anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse:282
    2021-02-03 20:55:07.332 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:07.333 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:08.546 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:08.560 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa mud</Setting> <Setting Type="String" Key="Cover">mud</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:08.590 WARNING: QString::arg: Argument missing: marsa mud, mud
    2021-02-03 20:55:08.596 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dse
    2021-02-03 20:55:08.597 WARNING: Script Error: Line 282
    2021-02-03 20:55:08.597 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:08.597 WARNING: Stack Trace:
    2021-02-03 20:55:08.598 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:08.598 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:17.075 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:17.088 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa mud</Setting> <Setting Type="String" Key="Cover">mud</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:17.118 WARNING: QString::arg: Argument missing: marsa mud, mud
    2021-02-03 20:55:17.124 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dse
    2021-02-03 20:55:17.125 WARNING: Script Error: Line 282
    2021-02-03 20:55:17.125 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:17.125 WARNING: Stack Trace:
    2021-02-03 20:55:17.126 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:17.126 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa mud.dsa
    2021-02-03 20:55:23.486 Rendering image
  • 2021-02-03 20:55:23.983 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilioneeyelashes_1008.jpg", pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
    2021-02-03 20:55:23.986 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionearms_1004.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.029 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionearmss_1004.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.090 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionearmsb_1004.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.102 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionelegs_1003.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.119 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionelegss_1003.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.126 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionelegsb_1003.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.129 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilioneeyes01_1007.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.161 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilioneeyesb_1007.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.166 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilioneface_1001.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.184 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionefaces_1001.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.194 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionefaceb_1001.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.200 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionemouth_1005.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.210 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionemouthb_1005.jpg", pixel type "Rgb", 2048x2048x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.223 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionetorso_1002.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.248 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionetorsos_1002.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.283 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\1_31427\runtime\textures\ozichick\lilione\ozi_lilionetorsob_1002.jpg", pixel type "Rgb", 4000x4000x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.347 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "D:\My Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2021-02-03 20:55:24.840 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2021-02-03 20:55:24.843 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2021-02-03 20:55:24.892 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2021-02-03 20:55:24.892 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2021-02-03 20:55:24.931 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 object with 544k triangles, 1 instance yielding 544k triangles) took 0.039s
    2021-02-03 20:55:24.939 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2021-02-03 20:55:24.947 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 101 textures, 0 lambdas (0 unique)
    2021-02-03 20:55:24.950 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2021-02-03 20:55:24.959 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2021-02-03 20:55:24.961 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2021-02-03 20:55:24.969 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2021-02-03 20:55:24.969 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2021-02-03 20:55:24.970 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2021-02-03 20:55:24.970 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2021-02-03 20:55:24.970 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-02-03 20:55:25.033 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2021-02-03 20:55:25.040 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2021-02-03 20:55:25.041 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2021-02-03 20:55:25.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 15 cores for rendering
    2021-02-03 20:55:25.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
    2021-02-03 20:55:25.142 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CUDA device 0 (GeForce GTX 1080 Ti)
    2021-02-03 20:55:25.142 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CPU
    2021-02-03 20:55:25.142 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2021-02-03 20:55:25.152 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend progr: CPU: Processing scene...
    2021-02-03 20:55:25.153 Iray [VERBOSE] - IRAY:RENDER ::   1.4   IRAY   rend progr: CUDA device 0 (GeForce GTX 1080 Ti): Processing scene...
    2021-02-03 20:55:25.161 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Using Embree 2.8.0
    2021-02-03 20:55:25.161 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Initializing Embree
    2021-02-03 20:55:25.163 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Geometry memory consumption: 14.7745 MiB (device 0), 0 B (host)
    2021-02-03 20:55:25.179 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : Using OptiX Prime version 5.0.1
    2021-02-03 20:55:25.179 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : Initializing OptiX Prime for CUDA device 0
    2021-02-03 20:55:27.081 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Importing lights for motion time 0
    2021-02-03 20:55:27.081 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Initializing light hierarchy.
    2021-02-03 20:55:27.093 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Light hierarchy initialization took 0.012s
    2021-02-03 20:55:27.098 Iray [VERBOSE] - IRAY:RENDER ::   1.2   IRAY   rend stat : Native CPU code generated in 0.000s
    2021-02-03 20:55:27.123 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Texture memory consumption: 167.644 MiB for 17 bitmaps (device 0)
    2021-02-03 20:55:27.132 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Lights memory consumption: 196 B (device 0)
    2021-02-03 20:55:27.132 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Materials memory consumption: 70.9336 KiB (GPU)
    2021-02-03 20:55:27.134 Iray [VERBOSE] - IRAY:RENDER ::   1.7   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
    2021-02-03 20:55:27.165 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Scene processed in 2.013s
    2021-02-03 20:55:27.170 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Allocated 27.0266 MiB for frame buffer
    2021-02-03 20:55:27.331 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Scene processed in 2.180s
    2021-02-03 20:55:27.335 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Allocated 27.0266 MiB for frame buffer
    2021-02-03 20:55:27.389 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Allocating 1-layer frame buffer
    2021-02-03 20:55:27.413 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iterations after 2.261s.
    2021-02-03 20:55:27.444 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Allocated 1.6875 GiB of work space (2048k active samples in 0.082s)
    2021-02-03 20:55:27.444 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Used for display, optimizing for interactive usage (performance could be sacrificed)
    2021-02-03 20:55:27.605 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 2.454s.
    2021-02-03 20:55:27.661 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 2.509s.
    2021-02-03 20:55:27.704 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 2.553s.
    2021-02-03 20:55:27.747 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 2.595s.
    2021-02-03 20:55:27.817 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 2.665s.
    2021-02-03 20:55:27.927 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00010 iterations after 2.776s.
    2021-02-03 20:55:28.032 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00012 iterations after 2.880s.
    2021-02-03 20:55:28.063 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00016 iterations after 2.912s.
    2021-02-03 20:55:28.222 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00021 iterations after 3.070s.
    2021-02-03 20:55:28.238 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00022 iterations after 3.086s.
    2021-02-03 20:55:28.377 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00027 iterations after 3.226s.
    2021-02-03 20:55:28.467 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00028 iterations after 3.315s.
    2021-02-03 20:55:28.633 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 90.05% of image converged
    2021-02-03 20:55:28.633 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00034 iterations after 3.481s.
    2021-02-03 20:55:28.727 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00035 iterations after 3.575s.
    2021-02-03 20:55:28.746 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00041 iterations after 3.594s.
    2021-02-03 20:55:28.944 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00042 iterations after 3.792s.
    2021-02-03 20:55:28.960 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00048 iterations after 3.808s.
    2021-02-03 20:55:29.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00054 iterations after 3.989s.
    2021-02-03 20:55:29.157 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00055 iterations after 4.005s.
    2021-02-03 20:55:29.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00061 iterations after 4.178s.
    2021-02-03 20:55:29.382 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00062 iterations after 4.230s.
    2021-02-03 20:55:29.606 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 92.98% of image converged
    2021-02-03 20:55:29.606 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00068 iterations after 4.454s.
    2021-02-03 20:55:29.651 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00069 iterations after 4.499s.
    2021-02-03 20:55:29.697 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00075 iterations after 4.545s.
    2021-02-03 20:55:29.911 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00076 iterations after 4.759s.
    2021-02-03 20:55:30.118 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(305): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : The 'iray_optix_prime' scene option is no longer supported.
    2021-02-03 20:55:30.118 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00088 iterations after 4.966s.
    2021-02-03 20:55:30.263 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00094 iterations after 5.111s.
    2021-02-03 20:55:30.297 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00096 iterations after 5.145s.
    2021-02-03 20:55:30.528 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 94.38% of image converged
    2021-02-03 20:55:30.528 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00102 iterations after 5.376s.
    2021-02-03 20:55:30.562 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00103 iterations after 5.411s.
    2021-02-03 20:55:30.640 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00109 iterations after 5.489s.
    2021-02-03 20:55:30.779 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00110 iterations after 5.627s.
    2021-02-03 20:55:30.833 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00116 iterations after 5.681s.
    2021-02-03 20:55:31.002 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00117 iterations after 5.850s.
    2021-02-03 20:55:31.013 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00123 iterations after 5.861s.
    2021-02-03 20:55:31.195 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00129 iterations after 6.043s.
    2021-02-03 20:55:31.221 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00130 iterations after 6.069s.
    2021-02-03 20:55:31.480 Iray [VERBOSE] - IRAY:RENDER ::   1.0   IRAY   rend progr: 95.64% of image converged
    2021-02-03 20:55:31.480 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00136 iterations after 6.329s.
    2021-02-03 20:55:31.492 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Convergence threshold reached.
    2021-02-03 20:55:31.809 Saved image: C:\Users\ekada\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    2021-02-03 20:55:31.822 Finished Rendering
    2021-02-03 20:55:31.871 Total Rendering Time: 8.48 seconds
    2021-02-03 20:55:31.887 Loaded image r.png
    2021-02-03 20:55:31.910 Saved image: C:\Users\ekada\AppData\Roaming\DAZ 3D\Studio4\temp\RenderAlbumTmp\Render 1.jpg
    2021-02-03 20:55:32.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2021-02-03 20:55:32.205 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti):      124 iterations, 2.398s init, 4.079s render
    2021-02-03 20:55:32.212 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU:      19 iterations, 2.028s init, 4.311s render
    2021-02-03 20:55:34.379 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa oil.dsa
    2021-02-03 20:55:34.392 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa oil</Setting> <Setting Type="String" Key="Cover">oil</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:34.422 WARNING: QString::arg: Argument missing: marsa oil, oil
    2021-02-03 20:55:34.429 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa oil.dse
    2021-02-03 20:55:34.430 WARNING: Script Error: Line 282
    2021-02-03 20:55:34.430 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:34.430 WARNING: Stack Trace:
    2021-02-03 20:55:34.431 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:34.439 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa oil.dsa
    2021-02-03 20:55:35.906 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dsa
    2021-02-03 20:55:35.920 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa moss</Setting> <Setting Type="String" Key="Cover">moss</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:35.950 WARNING: QString::arg: Argument missing: marsa moss, moss
    2021-02-03 20:55:35.964 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dse
    2021-02-03 20:55:35.965 WARNING: Script Error: Line 282
    2021-02-03 20:55:35.965 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:35.965 WARNING: Stack Trace:
    2021-02-03 20:55:35.966 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:35.974 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dsa
    2021-02-03 20:55:37.122 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dsa
    2021-02-03 20:55:37.137 DEBUG: <Settings> <Setting Type="String" Key="Title">marsa moss</Setting> <Setting Type="String" Key="Cover">moss</Setting> <Setting Type="String" Key="Comments"></Setting></Settings>
    2021-02-03 20:55:37.167 WARNING: QString::arg: Argument missing: marsa moss, moss
    2021-02-03 20:55:37.173 DEBUG: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dse
    2021-02-03 20:55:37.173 WARNING: Script Error: Line 282
    2021-02-03 20:55:37.173 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-02-03 20:55:37.173 WARNING: Stack Trace:
    2021-02-03 20:55:37.174 DEBUG: Error executing C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/MARSA Snow.dse
    2021-02-03 20:55:37.183 Script executed successfully: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/marsa elements/marsa moss.dsa
  • RiverSoft ArtRiverSoft Art Posts: 6,950
    Let's skip the install script for now.  It looks like even the regular scripts cannot find a function I wrote called ChangeFileExt, which should be in data/RiverSoft Art/Common/RSAdvHelperFunctions.dse.RS2020HelperFunctions.dse  Does that file exist?  and in the Daz Content manager paths?
    Post edited by RiverSoft Art on
    Experiment with MARSA Elements and Materia plugin.
    1920 x 1200 - 1M
    Post edited by Artini on
    LOL.  Looks good laugh
    Thanks, RiverSoft Art.
    Materia plugin is interesting, because it can create additional mesh, which can be used with any shaders.
    Need to do more experiments, but so far, I am impressed with both products, yours and Alessandro's.
    Not sure how to check, but would assume so, since I automatically installed it once through Connect, then uninstalled (because it wasn't functioning) and reinstalled through DIM. I never manually install things.
    MARSA Elements is very good for almost anything, but I especially like how nice it changes the look of the primitives,
    like the cylinder, used here as a simple icy ground.
    1000 x 1200 - 392K
    Easiest way to check is to search your content directories for RS2020HelperFunctions.dse.  I *think* Connect does not actually delete the files so it would be good to know if there are multiple versions of this file hanging around, which can occasionally cause problems.
    Thanks for the comment and sharing!  Marshian did a fantastic job with the shaders. smiley
    Yes, I agree. These shaders are a masterpiece of its own. The possibilities are endless...
    Just need a time to explore them even more.
    edited March 2021
    Hi, there is some update to MARSA Elements in DIM.
    Anybody has tried it?
    I would like not to screw up my installation, because I use MARSA Elements pretty often.
    The MARSA Elements update only updates some support files so that if you bought Pose Details you didn't overwrite the latest files.  Functionality is not changed.
    Copying Artini's post. I see an update in DIM today. Is this legit? Pretty frustrating when we can't trust if something is actually requiring an update or if it's another Daz flubb up. The Read Me lists nothing updated. Thanks in advance!
    edited March 2021
    Above post was removed as it wasn't immediately clear that it wa talking about a further, new update.
  • StingerStinger Posts: 328
    I'm getting errors after installation. Here's the log file. Is this a common issue and is there a known fix for this?
    2021-04-13 07:06:34.053 Beginning Install of "MARSA Elements"
    2021-04-13 07:06:41.976 "MARSA Elements": Install Succeeded.
    2021-04-13 07:06:51.240 Loading script: D:/Daz Connect Data/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
    2021-04-13 07:07:11.528 DEBUG: install custom marsa elements actions
    2021-04-13 07:07:11.528 DEBUG: Fa&vorites/MARSA Elements
    2021-04-13 07:07:11.529 DEBUG: D:/Daz Connect Data/data/cloud/1_80203/scripts/riversoft art/marsa elements/%1.dsa
    2021-04-13 07:07:11.529 DEBUG: D:/Daz Connect Data/data/cloud/1_80203/scripts/riversoft art/marsa elements/%1.png
    2021-04-13 07:07:13.082 WARNING: Script Error: Line 153
    2021-04-13 07:07:13.082 WARNING: ReferenceError: Can't find variable: ChangeFileExt
    2021-04-13 07:07:13.082 WARNING: Stack Trace:
        <anonymous>()@D:/Daz Connect Data/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa:153
    2021-04-13 07:07:13.083 Error in script execution: D:/Daz Connect Data/data/cloud/1_80203/scripts/riversoft art/marsa elements/install custom marsa elements actions.dsa
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    The logs shows that you have installed the product via Daz Connect. Most script-based products do not work with that way of installation. To fix this, completely uninstall the product and re-install it using DIM.
    edited April 2021
    After uninstalling this is what happens when I install through DIM.  When I click on 'Install Custom MARSA Elements Actions' an error meassage says the file does not exist.
    And if I right click on MARSA Elements and install from the Content Library, I get the 'file not found' error message in the photo below
    793 x 797 - 112K
    528 x 123 - 23K
    Post edited by Stinger on
