Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
I use Mythic3D's suggested folder structure (well, a version of it). Works great. I have a separate folder on my D drive cleverly called 'Daz Project Files.' I create a new subfolder for each project. Then for each project subfolder I have a Content subfolder for files to be shared and a Working Files subfolder for everything else.
Thank you Mythic3D for the folder tips.
And thank you Diva for the freebie.
It's a double mesh. Morphs are a lot easier to make with single meshes. To give some depth to the clothing some curl abit of mesh over the edge. That too can cause issues though as the figure is posed.
However a little post work never hurt anybody, it's a lovely set.
hahah Thanks guys - that is an old freebie I did years ago before I became a PA. It has issues but I'm glad some are still finding it useful. :)
Looks really cute but U can't download either with Chrome or Edge
I uploaded it as a freebie to Renderosity a few years ago - you should be able to download it there: https://www.renderosity.com/rr/mod/freestuff/?item_id=77666
Be warned, it was made before I became a PA and it was my first attempt at clothing so it's far from perfect. There are a lot of things I'd do differently if I were to do more clothing again in the future as I've learned a lot since then.
On the DA stash page, do not click on the upper right button that says Download. Rather click on the big center button - that works :-)
