Save a surface selection group or favorites or something? DS 4.15
3WC3WC Posts: 1,169
In DS 4.15 I am adjusting and converting to Iray an environment set with over 60 surfaces. For some materials presets I am working with the same set of 20-30 materials for each preset.
Is there a way to designate those surfaces as a group in favorites or something? It seems I am having to manually go through and reselect them each time I change something. I have been looking for a way to do this but am coming up empty.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,722
    do they share a property you can select by in rightclick in the viewport?
    even if it's a parameter for something like glossy reflectivity you change by 0.01
  • 3WC3WC Posts: 1,169
    Found it! In the surfaces tab menu there is a Material Selection Set Editor! Exactly what I was looking for.
