As of today I get this message when Daz Studio opens * SOLVED *
PetraPetra Posts: 1,157
edited January 2021 in Daz Studio Discussion
I have no idea why that is.
I got a new water cooler for my PC and mot RAM and a new tower.
Not sure if that can be the reason for this message?
It just started today.
Not sure what I need to do to make that message go away
Post edited by Petra on
  • barbultbarbult Posts: 27,416
    I have no idea, really. Have you logged into Daz from inside Daz Studio? If not, maybe that would help.
  • PetraPetra Posts: 1,157
    Yes, I did log in from within Daz studio.
    I never use Daz Connect though, this is very strange to me.
    It should go away if you log in from within Daz Studio, or if you set DS to NOT log in automatically.
  • It isn't, in any event, doing any actual harm - it means if you had encrypted Connect-only content it wouldn't open, but all of that was decrypted several years ago.
    It did affect some content like Gou Luck.
    The morphs did not at all apply to G8F.
    I have now logged in from withing DS and the message gone away.
    Thank you, that worked.:)
    I doubt the one caused the other.
    I am sure it did though because in the past I had bought characters they only worked when I installed them via connect, before that, with manual install, the morphs did not work at all.
    Sams as with Gou Luck.
    Only after I used to connect and installed it from within the studio, the morphs did work.
    Then your manual installation must have been done incorrectly, or your Content Directory Manager is not set to look in the place where you installed manually. By installing both manually and with Daz Connect, you have each file installed twice, wasting a tremendous amount of disc space. When products are installed with Daz Connect and another method, Daz Studio will always use the Daz Connect version.
    I do not like Daz Connect/ Smart Content, but for a few characters, I had to install with doing it because the morphs did not work at all.
    How can I uninstall the Daz connect installed products,
    When I install manually I do it correctly, it is easier for me, I know where what goes and I make sure all is installed where it should go.:)
    right-click on the Product icon in Smart Content>Products, or on the product container in the list under Products in the Content Library.
    Thank you so much Richard Haseltine, that worked and I could uninstall it :)
