How to hide shadows
Hi all
I am working on an trek render where the starship is in orbit around a planet. My problem is that the ship's shadow is being casted on the planet. How do you hide a shadow from an object?
  • Render it in separate layers so the ship isn't going to affect the planet and comp it in photoshop or whatever program you use for that.
  • vonHobovonHobo Posts: 1,715
    edited January 2021
    This may not be a solution for what you are trying to achieve, but maybe treat the shadow as a natural real-world byproduct?
    That means you would have to move the spaceship further from the planet to be believable, and also apply an atomosphere effect to fuzz out the shadow a bit.
    See my attached images with a car in space.
    1. Car with paper roll backdrop to show shadows.
    2. Paper roll removed (you can see a faint shadow from the car on the planet).
    3. Atmosphere gas added to scene (shadow is no longer prominent).
    You could also change the dome rotation so that the shadow does not fall directly on the planet but that might change how the ship appears in the light as well.
    835 x 835 - 924K
    825 x 825 - 879K
    826 x 826 - 1M
    Post edited by vonHobo on
  • NylonGirlNylonGirl Posts: 2,440
    If moving the ship further from the planet makes the planet too small, maybe the size of the planet could be increased too.
  • ZilvergrafixZilvergrafix Posts: 1,385
    Philippi_Child said:
    Hi all
    many ways to fix that!
    • 1-Render separately all except the ship, that render serves as Environment map
    • 2-Using iRay Canvases Beauty Mode.
    • 3-Using the method 1 AND using Powerpoint for resizing planet or ship.
    • 4-Render the ship in any degree and use it as a billboard
    • 5-Photoshop Layers
    Hi all
    I'm going to have to look up the Iray Canvases Beauty Mode. It sounds interesting.
