Harley Quinn Hair
I am a big Harley Quinn fan, and I was wondering if anyone knows of any models that would fit my needs, and/or even know if it would be possible to be made.
Basically I need pig tails that are posable (which I've found numerous ones that I love) but the problem is that I cannot adjust each tail's color independently. For example, I need the left one to be able to have red in it where as the right one needs black.
And I'd prefer it for V 4 rather than Genesis since I have skin textures that fit Harley already.
At least in poser, each pigtail in every hair I've tried actually shares the exact same map with the opposite one (so you can't load individual maps for each tail).
I'll try it out in DAZ to see if I can't create a new MAT zone this weekend, thanks.
recently i posted a script named mcjSphericalUV
there's a version for Daz Studio 1, 2, 3, 4, 4,5+
http://www.daz3d.com/forums/discussion/42361/
just now i zero-posed Aiko, i installed the XinXin hair prop ( not animatable )
http://www.daz3d.com/xinxin-for-aiko-3
i created a camera and placed it inside aiko's head
i made this camera the current view camera
i selected the xinxin hair node
i ran the script and specified i wanted the UV map to be projected from the point of view of the camera
1 minute later i had a copy of the hair prop with the new UV mapping
i then applied the very simple red/black image-map shown below to the hair diffuse color channel
done
note: i did this in Daz Studio 3, it should work with DS4.5+ but i didnt do many tests in DS4.5
note: this script saves a copy of the posed / scaled / positioned objects,
it's far from guaranteed you can use the obj file as the geometry of a figure and expect it to still be an animatable/posable figure
