[Released] ManFriday's dForce Companion [Commercial]
13»
  • Richard Haseltine said:
    videoninja719 said:
    is this a dforce maker or something. i am looking for something that can make a cloth from marvelous designer into dforce
    With the imported item selected, Edit>Figure>Geometry>Add dForce Modifier : Dynamic Surface. Optionally you can rig it by having the item and the figure loaded (the clothing has to fit on the figure without modification) and using Edit>Figure>Transfer Utility, setting the Source to the figure and the imported object as the Target.
    Thank you sir. This really helps!!!
  • JamieMJamieM Posts: 356
    Any ideas why some dforce products don't show up at all in the dforce companion menu (and therefore can't be selected / deselected or used with the companion)?
    Recently I've found https://www.daz3d.com/dforce-laundry and https://www.daz3d.com/dforce-jw-classic-bed .
  • any update for a mac version?
  • DolbomirDolbomir Posts: 73
    edited July 2021
    Hello.
    Did one of the recent updates break this plugin?
    I'm running DAZ 14.15.0.2 and have ManFriday's dForce Companion V1.0.1. Lately nothing ever shows up in the plugin's pane.
    The plugin shows in the "About Installed Plugins" with a green plug icon and the pane shows. Checking "Show all" and hitting the refresh-looking button does nothing.
    Thanks
    EDIT: my bad, I just forgot to convert props to figures... Going to keep this comment instead of deleting it in case others forget that step and are similarly confused... Sorry!
    1906 x 813 - 360K
    Post edited by Dolbomir on
  • LoonyLoony Posts: 1,817
    Dolbomir said:
    Hello.
    Thanks
    the plugin is atm. just made for clothes on chars, not for props around in the scene, those are mainly not listed, but its a wanted feature.
    For some reason, I remember using that plugin for props as well. That being said, there is a workaround: converting the prop to figure (via Edit > Object > Rigging > Convert Prop to Figure).
    really?
    Most times it will not list the props, like a towel in the bath, when its not fitted to a char, it will be ignored.
  • barbultbarbult Posts: 26,915
    Loony said:
    really?
    You just have to convert the prop to a figure, as mentioned several times above. That is what ManFriday recommended.
    barbult said:
    Loony said:
    really?
    I never made that, just the opposite :D
    BUt I will try to remember that, when I have a prop to dforce again :)
  • jardinejardine Posts: 1,220
    hi...
    i love this tool.  i can't imagine dforcing without it.
    i would like to request an option to keep the simulation variables visible permanently.  or as the default behavior.  i've lost track of the times i've thought i was going to be simulating a single frame, but 'simulate from animated pose has kicked in'.  and that does put a bit of an ongoing dent in the tool's otherwise stellar time-saving capabilities.
    thanks!
    j
  • ManFridayManFriday Posts: 569
    jardine said:
    hi...
    thanks!
    j
    I have run into the same situation, but I don't think it would be a good idea for dForce Companion to change that. The simulation settings are global to Daz Studio, and the dForce Companion tab just displays them and allows you to change them. It's just another interface to what you can see on Daz Studio's "Simulation settings" pane. I'm afraid if I force certain settings to be changed it will lead to compatibility problems on other people's systems.
    Simulation settings are saved with the scene though. If you feel strongly about it, you can save a scene file with your simulation settings and load that by default in Daz Studio (Preferences -> Studio -> Load file). If you load another scene file though, the setting will be changed by the new scene file again though.
    ManFriday said:
    jardine said:
    hi...
    thanks!
    j
    I don't think jardine was asking you to change the simulation settings values, just to make the settings visible by default in the dForce Companion pane. As it is now, we have to check the box every time to make the settings visisble.
    barbult said:
    ManFriday said:
    jardine said:
    hi...
    thanks!
    j
    @barbult is right on target.  (as usual!  for which, thanks!)
    i'm just wishing for an option to keep the interface from hiding those essential details.  as is, the hidden 'simulate from default pose' setting is a bit of a workflow trap.
    j
    Sorry. Read that too quickly. It's noted for the next release, but I have a number of things piled up that need to be released first. Thank you for the suggestion!
  • cdotdkcdotdk Posts: 23
    edited November 2022
    Having just gone through the pain of a complete reinstall (DazCentral... you and me are not gonna stay friends), I now get an exception whenever I switch to the dForce Companion pane. Not sure what's up. I've tried re-installing it, but it made no difference. Exception only happens when there are actual dForce items in the scene.
    Here are the details.
    1. Plugin seems to load fine during startup
    2022-11-26 15:06:35.586 [INFO] ::       MF_dforce.dll
    2022-11-26 15:06:35.591 [INFO] ::       MF_meshgrab.dll
    2022-11-26 15:06:35.597 [INFO] ::       MF_meshmorph.dll
    2022-11-26 15:06:35.602 [INFO] ::       MF_meshrot.dll
    2022-11-26 15:06:35.609 [INFO] ::       MF_renderq.dll
    2022-11-26 15:06:35.615 [INFO] ::       sdk_sceneinfopane.dll
    2022-11-26 15:06:35.633 [INFO] ::       dzdrawstyles.dll
    2022-11-26 15:06:35.645 [INFO] ::       dzpowerpose.dll
    2. I then load up my scene and am immediately met with 2 exceptions. I can ignore both and then, at least on the surface, the plugin appears to do what it usually does.
    Here's what comes into the log.
    2022-11-26 15:11:17.303 [WARNING] :: QObject::connect: Cannot connect (null)::modifierAdded(DzModifier*) to FrSkeleton::slotOnModifierAdded(DzModifier*)
    Am also attaching the more detailed error exception popup that ... duh... pops up :D
    And if it helps, here's the files involved in the scene.
    2022-11-26 15:11:09.464 [INFO] :: Start following: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.464 [INFO] :: Following started: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.464 [INFO] :: Connect base morphs: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.474 [INFO] :: Creating morph projection map: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.479 [INFO] :: Base morphs connected: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.479 [INFO] :: Creating morph projection map: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:09.480 [INFO] :: Start following: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.480 [INFO] :: Following started: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.480 [INFO] :: Connect base morphs: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.481 [INFO] :: Creating morph projection map: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.485 [INFO] :: Base morphs connected: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.485 [INFO] :: Creating morph projection map: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.486 [INFO] :: Start following: E3D Maya HD << Skirt
    2022-11-26 15:11:09.486 [INFO] :: Following started: E3D Maya HD << Skirt
    2022-11-26 15:11:09.486 [INFO] :: Connect base morphs: E3D Maya HD << Skirt
    2022-11-26 15:11:09.488 [INFO] :: Creating morph projection map: E3D Maya HD << Skirt
    2022-11-26 15:11:09.494 [INFO] :: Base morphs connected: E3D Maya HD << Skirt
    2022-11-26 15:11:09.494 [INFO] :: Creating morph projection map: E3D Maya HD << Skirt
    2022-11-26 15:11:09.496 [INFO] :: Start following: E3D Maya HD << Shoes
    2022-11-26 15:11:09.496 [INFO] :: Following started: E3D Maya HD << Shoes
    2022-11-26 15:11:09.496 [INFO] :: Connect base morphs: E3D Maya HD << Shoes
    2022-11-26 15:11:09.499 [INFO] :: Creating morph projection map: E3D Maya HD << Shoes
    2022-11-26 15:11:09.505 [INFO] :: Base morphs connected: E3D Maya HD << Shoes
    2022-11-26 15:11:09.505 [INFO] :: Creating morph projection map: E3D Maya HD << Shoes
    2022-11-26 15:11:09.507 [INFO] :: Start following: E3D Maya HD << Blouse
    2022-11-26 15:11:09.507 [INFO] :: Following started: E3D Maya HD << Blouse
    2022-11-26 15:11:09.507 [INFO] :: Connect base morphs: E3D Maya HD << Blouse
    2022-11-26 15:11:09.510 [INFO] :: Creating morph projection map: E3D Maya HD << Blouse
    2022-11-26 15:11:09.515 [INFO] :: Base morphs connected: E3D Maya HD << Blouse
    2022-11-26 15:11:09.516 [INFO] :: Creating morph projection map: E3D Maya HD << Blouse
    2022-11-26 15:11:09.516 [INFO] :: Start following: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.517 [INFO] :: Following started: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.517 [INFO] :: Connect base morphs: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.596 [INFO] :: Creating morph projection map: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.601 [INFO] :: Base morphs connected: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.602 [INFO] :: Creating morph projection map: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:09.822 [INFO] :: Finalizing scene data...
    2022-11-26 15:11:09.850 [INFO] :: Finished asset load (open): 0m 6.97s - /D:/Dropbox/Test/Tests/Photo Sorceress Test.duf
    2022-11-26 15:11:09.852 [INFO] :: Processing morph projection queue: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:09.853 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/DAZ 3D/Genesis 8/Female/Morphs/kaluma/FemGens_G8F-JCMs/jcmRightTightBendG8F.dsf
    2022-11-26 15:11:09.854 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/kaluma/FemGens_G8F-JCMs/jcmLeftTightBendG8F.dsf
    2022-11-26 15:11:09.855 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Flexions/pJCMFlexHamstring_R.dsf
    2022-11-26 15:11:09.857 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Flexions/pJCMFlexHamstring_L.dsf
    2022-11-26 15:11:09.858 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Flexions/pJCMFlexCalf_R.dsf
    2022-11-26 15:11:09.859 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Flexions/pJCMFlexCalf_L.dsf
    2022-11-26 15:11:09.860 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMToesUp_60_R.dsf
    2022-11-26 15:11:09.861 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMToesUp_60_L.dsf
    2022-11-26 15:11:09.863 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb3Bend_90_R.dsf
    2022-11-26 15:11:09.864 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb3Bend_90_L.dsf
    2022-11-26 15:11:09.865 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb2Bend_65_R.dsf
    2022-11-26 15:11:09.866 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb2Bend_65_L.dsf
    2022-11-26 15:11:09.867 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb1Up_20_R.dsf
    2022-11-26 15:11:09.869 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb1Bend_50_R.dsf
    2022-11-26 15:11:09.870 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThumb1Bend_50_L.dsf
    2022-11-26 15:11:09.871 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThighFwd_57_R.dsf
    2022-11-26 15:11:09.873 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThighFwd_57_L.dsf
    2022-11-26 15:11:09.874 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMThighFwd_115_R.dsf
    2022-11-26 15:11:09.875 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrFwd_110_R.dsf
    2022-11-26 15:11:09.877 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrFwd_110_L.dsf
    2022-11-26 15:11:09.878 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrFront_p110_Bend_p40_R.dsf
    2022-11-26 15:11:09.879 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrFront_n110_Bend_n40_L.dsf
    2022-11-26 15:11:09.881 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrDown_40_R.dsf
    2022-11-26 15:11:09.882 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShldrDown_40_L.dsf
    2022-11-26 15:11:09.883 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShinBend_90_R.dsf
    2022-11-26 15:11:09.885 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShinBend_90_L.dsf
    2022-11-26 15:11:09.886 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMShinBend_155_R.dsf
    2022-11-26 15:11:09.887 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMRing2Dwn_105_L.dsf
    2022-11-26 15:11:09.888 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMRing1Dwn_95_L.dsf
    2022-11-26 15:11:09.889 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMPinky2Dwn_105_L.dsf
    2022-11-26 15:11:09.891 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMPinky1Dwn_95_R.dsf
    2022-11-26 15:11:09.892 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMPinky1Dwn_95_L.dsf
    2022-11-26 15:11:09.893 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMPelvisFwd_25.dsf
    2022-11-26 15:11:09.894 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMNeckTwist_22_R.dsf
    2022-11-26 15:11:09.895 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMNeckLowerSide_40_R.dsf
    2022-11-26 15:11:09.897 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMNeckFwd_35.dsf
    2022-11-26 15:11:09.898 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMMid2Dwn_105_L.dsf
    2022-11-26 15:11:09.899 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMMid1Dwn_95_L.dsf
    2022-11-26 15:11:09.900 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMIndex2Dwn_105_R.dsf
    2022-11-26 15:11:09.901 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMIndex2Dwn_105_L.dsf
    2022-11-26 15:11:09.902 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMIndex1Dwn_90_L.dsf
    2022-11-26 15:11:09.903 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMHeadBack_27.dsf
    2022-11-26 15:11:09.905 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMHandDwn_70_R.dsf
    2022-11-26 15:11:09.906 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMHandDwn_70_L.dsf
    2022-11-26 15:11:09.907 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMForeArmFwd_75_R.dsf
    2022-11-26 15:11:09.908 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMForeArmFwd_75_L.dsf
    2022-11-26 15:11:09.909 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMFootDwn_75_R.dsf
    2022-11-26 15:11:09.911 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMFootDwn_75_L.dsf
    2022-11-26 15:11:09.912 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMCollarUp_55_R.dsf
    2022-11-26 15:11:09.913 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMCollarUp_55_L.dsf
    2022-11-26 15:11:09.915 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMCollarTwist_n30_R.dsf
    2022-11-26 15:11:09.916 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMCollarTwist_n30_L.dsf
    2022-11-26 15:11:09.917 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMChestFwd_35.dsf
    2022-11-26 15:11:09.918 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMAbdomenUpperFwd_Navel.dsf
    2022-11-26 15:11:09.919 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMAbdomenLowerFwd_Navel.dsf
    2022-11-26 15:11:09.921 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMAbdomenFwd_35.dsf
    2022-11-26 15:11:09.922 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base Correctives/pJCMAbdomen2Fwd_40.dsf
    2022-11-26 15:11:09.926 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Exart3D/E3D Maya/E3D Maya Head.dsf
    2022-11-26 15:11:09.935 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Exart3D/E3D Maya/E3D Maya Body.dsf
    2022-11-26 15:11:09.936 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Head/PHMEyelashesLengthUpper.dsf
    2022-11-26 15:11:09.937 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Head/PHMEyelashesLengthLower.dsf
    2022-11-26 15:11:09.938 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Head/PHMEyelashesCurl.dsf
    2022-11-26 15:11:09.939 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpRight_div2.dsf
    2022-11-26 15:11:09.941 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpRight_div2_proj.dsf
    2022-11-26 15:11:09.943 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpLeft_div2.dsf
    2022-11-26 15:11:09.945 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpLeft_div2_proj.dsf
    2022-11-26 15:11:09.946 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_bs_EyeLookOutRight_div2.dsf
    2022-11-26 15:11:09.948 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_bs_EyeLookOutRight_div2_proj.dsf
    2022-11-26 15:11:09.949 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/FACS/facs_bs_EyeLookInLeft_div2.dsf
    2022-11-26 15:11:09.951 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_bs_EyeLookInLeft_div2_proj.dsf
    2022-11-26 15:11:09.955 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Exart3D/E3D Maya/E3D Maya HD Details.dsf
    2022-11-26 15:11:10.091 [INFO] :: Morph projection queue processed: E3D Maya HD << E3D Maya Tear
    2022-11-26 15:11:10.091 [INFO] :: Processing morph projection queue: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:10.096 [INFO] :: Morph projection queue processed: E3D Maya HD << E3D Maya Eyelashes
    2022-11-26 15:11:10.096 [INFO] :: Processing morph projection queue: E3D Maya HD << Skirt
    2022-11-26 15:11:10.110 [INFO] :: Morph projection queue processed: E3D Maya HD << Skirt
    2022-11-26 15:11:10.110 [INFO] :: Processing morph projection queue: E3D Maya HD << Blouse
    2022-11-26 15:11:10.123 [INFO] :: Morph projection queue processed: E3D Maya HD << Blouse
    2022-11-26 15:11:10.123 [INFO] :: Processing morph projection queue: E3D Maya HD << Shoes
    2022-11-26 15:11:10.137 [INFO] :: Morph projection queue processed: E3D Maya HD << Shoes
    2022-11-26 15:11:10.539 [INFO] :: Unlocking viewport redraw...
    2022-11-26 15:11:10.539 [INFO] :: Viewport redraw unlocked.
    2022-11-26 15:11:10.542 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base/PHMMouthRealism_HD_div2.dsf
    2022-11-26 15:11:10.546 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base/PBMNavel.dsf
    2022-11-26 15:11:10.547 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Daz 3D/Mouth Realism/PHMMouthRealism8_1_HD_div4.dsf
    2022-11-26 15:11:10.628 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Exart3D/E3D Maya/E3D Maya Tear/Morphs/Exart3D/E3D Maya/E3D Maya TearFix.dsf
    2022-11-26 15:11:10.716 [INFO] :: Loaded morph deltas: 0m 0.53s - /data/Neftis3D/Alyssa BaseCap G8F/Alyssa BaseCap G8F/Morphs/Neftis3D/Base/FHMExpandAll.dsf
    2022-11-26 15:11:14.152 [INFO] :: Loaded image: HLE3D Maya-Head.jpg
    2022-11-26 15:11:14.273 [INFO] :: Loaded image: HLE3D Maya-Legs.jpg
    2022-11-26 15:11:14.307 [INFO] :: Loaded image: HLE3D Maya-Eyes-01.jpg
    2022-11-26 15:11:14.436 [INFO] :: Loaded image: HLE3D Maya-Arms.jpg
    2022-11-26 15:11:14.556 [INFO] :: Loaded image: HLE3D Maya-Teeth.jpg
    2022-11-26 15:11:14.687 [INFO] :: Loaded image: HLE3D Maya-Face.jpg
    2022-11-26 15:11:14.752 [INFO] :: Loaded image: HLE3D Maya-Lipsnat.jpg
    2022-11-26 15:11:14.862 [INFO] :: Loaded image: HLE3D Maya-Torso.jpg
    2022-11-26 15:11:14.965 [INFO] :: Loaded image: Jewelry_BaseColor.jpg
    2022-11-26 15:11:15.096 [INFO] :: Loaded image: skirt_BaseColor.jpg
    2022-11-26 15:11:15.288 [INFO] :: Loaded image: Shoes_BaseColor.jpg
    2022-11-26 15:11:16.055 [INFO] :: Loaded image: LasText.jpg
    2022-11-26 15:11:16.478 [INFO] :: Loaded image: WoodPlanksFloors0010_1_S.jpg
    2022-11-26 15:11:16.539 [INFO] :: Loaded image: Wood_10.jpg
    2022-11-26 15:11:16.556 [INFO] :: Loaded image: Paper.jpg
    2022-11-26 15:11:16.630 [INFO] :: Loaded image: Grunge.png
    2022-11-26 15:11:16.651 [INFO] :: Loaded image: BrickSmallBrown0470_5_seamless_S.jpg
    2022-11-26 15:11:16.669 [INFO] :: Loaded image: HLE3D Maya Eyelashes.png
    2022-11-26 15:11:16.685 [INFO] :: Loaded image: Tear Opacity.jpg
    2022-11-26 15:11:16.781 [INFO] :: Loaded image: Blouse_BaseColor.jpg
    2022-11-26 15:11:16.854 [INFO] :: Loaded image: Blouse_Opacity.jpg
    2022-11-26 15:11:16.902 [INFO] :: Loaded image: CaptexAPT.jpg
    2022-11-26 15:11:16.955 [INFO] :: Loaded image: CapTrAPT -.jpg
    2022-11-26 15:11:16.963 [INFO] :: Loaded image: APTstrTR.jpg
    2022-11-26 15:11:17.317 [INFO] :: Processing morph projection queue: E3D Maya HD << Alyssa Base Cap G8F
    2022-11-26 15:11:17.648 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpRight_div2_proj.dsf
    2022-11-26 15:11:17.655 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_cbs_EyeLookUpLeft_div2_proj.dsf
    2022-11-26 15:11:17.662 [INFO] :: Loaded first morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 8/Female 8_1/Projection Morphs/Daz 3D/FACS/facs_bs_EyeLookOutRight_div2_proj.dsf
    Any idea what's up?
    615 x 426 - 67K
    Post edited by cdotdk on
    Ok so I got it working. It seems, no matter how hard I try, Daz Connect just pulls be back in :D
    In case anyone else runs into this; after my re-install I had basically decided to not deal with Daz Connect at all. What a terrible PoS that is - but I guess that's a story for a different day.
    Then I realised, it wasn't only dForce Companion giving me trouble. Scripts for Camera Magic were failing as well - and that led me to this thread: https://www.daz3d.com/forums/discussion/335261/unable-to-run-scripts
    So following what I learned in this thread, that there's apparently some kind of DRM scheme thing going on, I downloaded Daz Connect (again), opened it up. Did NOTHING else. And like magic, everything began working again.
    Happy that it's solved, not happy how it had to be solved. But I guess all of this has nothing to do with the actual product here - which I think is absolutely a great product, I might add. I'm a fan :)
  • DarkElfDarkElf Posts: 519
    Love this tool. Used to use it often. Now it's gone. Can't find it in my plugins. I uninstalled it and reinstalled but still can't find it in my plugins.
