DazConnect : Corrupted downloads
13
  • Noah LGPNoah LGP Posts: 2,617
    edited December 2020
    dragoneyes002 said:
    using an SSD or a HDD? and if an SSD how old is it?
    It's a server issue, I'm using 2 computers, one is new (november 2020).
    There is no issue with DIM.
    Post edited by Noah LGP on
    edited February 2021
    Yet another product is broken by an update (unreadable files) :
    • 53565 The Crib
    64783 FuryX update failed :
    2021-02-27 13:02:16.605 Beginning Update of "FuryX"
    2021-02-27 13:02:17.152 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.png.part"
    2021-02-27 13:02:17.157 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.part"
    2021-02-27 13:02:17.160 "FuryX": Update Failed.
    edited March 2021
    80611 Knit: St. Patrick's Day is missing in Daz Connect (only available in DIM)
  • m1337sxmm1337sxm Posts: 6
    It seems to me that after I added the free Knit St Patrick's Day shader in 3 parts (when I saw 3 parts I knew it was trouble) I now get installed products that have ??? thumbnails for many things I try to install via DIM or interactive from inside Daz.  The error on that Knit shader below can't find the JSON file it needs from Daz.  Ugh I need the thumbnails in Smart Content to be there as they should be.
    2021-03-17 12:23:33.972 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json) failed: HTTP response code said error
    2021-03-17 12:23:33.972 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (80611) failed, url: https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json
    2021-03-17 12:23:33.973 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed with errors, 2 items succeeded, 1 items failed.
    edited April 2021
    Daz Connect updated the metadata for 2518 of 6008 installed products but these errors still occur
    2021-04-10 14:36:14.770 Updated metadata for 0 of 1 items.2021-04-10 14:36:16.641 Updated metadata for 1 of 2 items.2021-04-10 14:36:48.592 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json) failed: HTTP response code said error2021-04-10 14:36:48.592 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (80611) failed, url: https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json2021-04-10 14:36:48.592 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed with errors, 1 items succeeded, 1 items failed.2021-04-10 14:36:48.592 Metadata update failed: 1 items succeeded, 1 items failed.2021-04-10 14:42:30.493 Beginning Update of "The King’s Son HD for Genesis 8 Male"2021-04-10 14:42:31.023 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.dsa.part"2021-04-10 14:42:31.027 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.jpg.part"2021-04-10 14:42:31.029 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_55419\runtime/support/daz_3d_55419_the_king?s_son_hd_for_genesis_8_male.dsx.part"2021-04-10 14:42:31.057 "The King’s Son HD for Genesis 8 Male": Update Failed.2021-04-10 14:42:32.976 Beginning Update of "FuryX"2021-04-10 14:42:33.826 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.png.part"2021-04-10 14:42:33.899 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.part"2021-04-10 14:42:33.944 "FuryX": Update Failed.
    2021-06-18 13:47:38.268 Beginning Install of "Queen Hetepheres' Sedan Chair"2021-06-18 13:47:38.627 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Sedan_Chair.ds props/hetepheres sedan/sedan_chair.ds in product Queen Hetepheres' Sedan Chair 69982021-06-18 13:48:21.323 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=6998&file_path=props/hetepheres sedan/sedan_chair.ds&SID=5P66k6J-EPv-2PfFfti3pBanvMSenjmkq5fa7ZtMaib_C4ToboAp1A) failed: HTTP response code said error2021-06-18 13:48:21.323 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): getFileInformation failed, url: https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=6998&file_path=props/hetepheres sedan/sedan_chair.ds&SID=5P66k6J-EPv-2PfFfti3pBanvMSenjmkq5fa7ZtMaib_C4ToboAp1A2021-06-18 13:48:21.323 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_6998\props/hetepheres sedan/sedan_chair.ds.part"2021-06-18 13:48:21.376 "Queen Hetepheres' Sedan Chair": Install Failed.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • I ran into this with a lot of products after a fresh install, and am still compiling my list (nearly 300 now and I'm less than halfway through) of broken products.  This has already cost me many, many hours and there is, frankly, no excuse for this.  DAZ should, certainly by now, be proactively running scripts on their server to detect these errors and prioritize fixing them.
    I am done buying products from DAZ until/unless they fix this mess.
  • barbultbarbult Posts: 26,380
    The all zero GUID is usually on old (very old) product for me. You should still be able to find those in your Content Library and Smart Content, though. Here is an example of an old V4 era product installed with Daz Connect. It has a GUID that is all zero. I can see it in the Content Library virtual folder, the Content Library Products section, and Smart Content.
    608 x 872 - 247K
    1566 x 841 - 305K
    594 x 594 - 141K
  • To be sure, the GUID=0 is a separate issue from the many, many products with corrupt texture files that DAZ should have already found and fixed on their side.
    edited May 2022
    Redacted
  • I thought the whole point of metadata was to support "Smart Content"; so how on Earth can they justify saying "metadata issues" won't be fixed?
    edited May 2022
    Redacted
  • I just wish there was a way to hide content for DAZ Connect via Smart Content. I have content that I rarely use and it'll look so much nicer to have old content (pre-genesis 1 era) hidden and ignored from being checked every time I login in DAZ Studio.
  • I'm more worried about Connect giving us corrupted and unusable textures for a significant number of products that we paid for, and that DAZ hasn't fixed it in over a year.
    New feature requests should go in their own thread, rather than derailing this one.
    edited June 2021
    New product
    2021-06-19 10:32:26.857 Beginning Update of "Cyber Man Outfit for Genesis 8 Males"2021-06-19 10:32:27.222 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Data/3D/DAZ/Connect\data\cloud\1_81879\runtime/textures/sade/cyberman/zipper/zipper_roughness m?solata.jpg.part"2021-06-19 10:32:27.236 "Cyber Man Outfit for Genesis 8 Males": Update Failed.
    Generation 4 figures and their morphs are products that wil not work with Connect.  Just stop using Connect and most of your problems will be solved.
    The overwhelming number of products that are broken on Connect are not Gen4, they are products that previously worked with Connect and were later broken by DAZ .  I have dozens of projects that I can no longer successfully open and work on, as well as products (over 300 now) that I can no longer use.
    That is what this thread is about; don't side-track onto the "Missing GUID for Gen4 Products issue", which should probably be in its own thread.
    We have yet to hear a remediation plan for this serious, systemic problem which has been dragging on for over a year, now.
    The remedy is not to use Connect.  It doesn't work with plug-ins, true shaders and some scripts.  You would to need to either use DIM or Central to install those so just use DIM (preferably) or Central anyways.
  • Richard HaseltineRichard Haseltine Posts: 108,617
    Not "true" sahders, just older shaders.
  • KlimaxKlimax Posts: 23
    Currently I see broken following broken products on DAZ Cloud:
    BRC - Tranquility (3232)
    Carnival Midway Interiors (13141)
    Ultimate Lights and Backgrounds Bundle (29934)
    EJ Easy Face Generator for G8 (61521)
    Lake Muirne (71505)
    X-Fashion Sexy Sweet Lingerie for G8 Female (73447)
    DigiVaults Outer Marker (78722)
    Product "Secret Garden Shaded Haven" (13305) can't be installed from DAZ Cloud at all. It fails immediately and shows in Smart Pane as "Product #13305".
    edited July 2021
    78267 dForce 27 Hours for Genesis 8 Males
    Missing folders :
    • People\Genesis 8 Male\Clothing\27 Hours\Materials
    • Runtime\Textures
    Daz Connect can't download the files for :
    • 78724 dForce Niko Outfit for Genesis 8 Males
    • 79591 Cyberpunk Car
    • 79592 dForce 27 Hours Outfit Textures
    2021-06-21 15:27:32.700 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/24/78724/enc/22a6b3bd64f071ff6aa44d5929c38a4a_cc584a.enc) failed: HTTP response code said error2021-06-21 15:27:32.700 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_78724\runtime/textures/sademoonscape/niko outfit/3/defaultmaterial_base_color_1011.jpg.part"
    2021-06-21 15:21:37.385 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=79591&file_path=vehicles/cyberpunk car/cyberpunk car.tip.png&SID=ok9sTfQkxUE8ZBNlZ5iFUL1-6VPfNv-D4BUY-N_XLDMSoZ3j6gStGA) failed: HTTP response code said error2021-06-21 15:21:37.385 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): getFileInformation failed, url: https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=79591&file_path=vehicles/cyberpunk car/cyberpunk car.tip.png&SID=ok9sTfQkxUE8ZBNlZ5iFUL1-6VPfNv-D4BUY-N_XLDMSoZ3j6gStGA
    2021-06-21 15:41:04.396 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=79592&file_path=people/genesis 8 male/clothing/27 hours/materials/27hours mikey socks.png&SID=ok9sTfQkxUE8ZBNlZ5iFUL1-6VPfNv-D4BUY-N_XLDMSoZ3j6gStGA) failed: HTTP response code said error2021-06-21 15:41:04.396 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): getFileInformation failed, url: https://hpclscruffy.daz3d.com/Customer/get_download_path?product_id=79592&file_path=people/genesis 8 male/clothing/27 hours/materials/27hours mikey socks.png&SID=ok9sTfQkxUE8ZBNlZ5iFUL1-6VPfNv-D4BUY-N_XLDMSoZ3j6gStGA
  • evilded777evilded777 Posts: 2,485
    cridgit said:
    I filed a bug report for Queen Hetepheres Sedan Chair yesterday, same problem for me.
    Also discovered using a script I wrote that I have >600 products not showing AT ALL in Smart Contect/DAZ Connect because they have a missing GUID. So I purchased these products but can't use them without manually installing. I filed a bug report months ago and they just closed it without even reading what I wrote.
    I'd like to use this script, please? Hell, I'd pay to use this script.
    Yeah... what's this now?
    More broken products: Sacrament font (12635)
    Parkside Freight (15103)
    Bus Maxis (15450)
    Deco living 1 (15961)
    Elevator Hallway (16975)
    I'm real new here.  Can you explain this in better detail?
    edited June 2021
    2021-06-26 11:19:48.358 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_6998\props/hetepheres sedan/sedan_chair.ds.part"2021-06-26 11:19:48.360 "Queen Hetepheres' Sedan Chair": Update Failed.2021-06-26 11:19:49.363 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_15961\environments/architecture/dec_living_1/scenes/!pre_dbl_sofa.duf.part"2021-06-26 11:19:49.363 "Deco Living 1": Update Failed.2021-06-26 11:20:30.168 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "C:/Data/3D/DAZ/Connect\data\cloud\1_8949\environments/architecture/oneiros/oneiros.ds.part"2021-06-26 11:20:30.219 "Oneiros": Update Failed.2021-06-26 11:22:10.411 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Yellow.duf vehicles/bus maxis/materials/yellow.duf in product Bus Maxis 154502021-06-26 11:22:10.411 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Maxis.duf vehicles/bus maxis/maxis.duf in product Bus Maxis 154502021-06-26 11:22:10.411 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Green.duf vehicles/bus maxis/materials/green.duf in product Bus Maxis 154502021-06-26 11:22:10.412 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file G Driver.duf people/genesis/pose/bus maxis/g driver.duf in product Bus Maxis 154502021-06-26 11:22:10.412 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Blue.duf vehicles/bus maxis/materials/blue.duf in product Bus Maxis 154502021-06-26 11:23:35.247 "Bus Maxis": Update Failed.
    edited July 2021
    dForce 27 Hours for Genesis 8 Males, Deco Living 1 and Bus Maxis are fixed.
    edited May 2022
    Redacted
