What does your Daz Layout look like?
pjwhoopie4801218
in New Users
Greetings
I have been running the default Daz theme/layout with everything in it's default location.
Lately, I've been noticing when I watch a Daz Tutorial, that often, the TUT Author's set up is far from the default. I am guessing years of using Daz in all its iterations has honed their work flow to be as efficient for them as possible.
As I newbie though, color me intrigued.
If you are using something other than the default, you mind posting a screenshot and giving a tiny explantion of why-you-have-it-the-way-you-have-it?
I know everyone is different, but hey, I don't know what I don't know, so I love to see what works for you!
Three monitors, left = Content Library, middle = Scene and Parameters, right = Viewport
Mine is heavily customized -- no "rooms", no toolbars, lots of extra menus on the top menu bar.
Mine isn't far from the default. I like the biggest veiwport I can get and all the panes I need have tabs along the side of the other window in the viewpoprt to the left. i also have my toolbar across the top and the most used items in the scripts dropdown
I NEVER use smart content or connect and find everything thru the content library like it is installed.
i think i just use the default workspace.
I put some effort into customisation a year or so ago but I didnt save as preset and lost it when i reinstalled.
The only modification i made to my current layout was adding Mesh Grabber tool into the main tool menu.
I too never use Smart Content or Connect so I have the Content tree open to find my stuff. I have quite a few Custom shortcuts, some of which I have created icons for and put them in various toolbars. Sometimes an update breaks the layout so I have to start over but maybe I find better options when I do that so I don't mind too much. The placing of actions/icons on the toolbars tends to be pretty unstable and it often happens that if I minimise the screen and then go back to Full Screen, they have all shifted position. A small annoyance but I can restore it by minimising and going back to Full Screen again.
That is an interesting layout Marble. I like the icons to the side and top. Interesting that your library starts with DIM CONTENT.
Is it possible to export a layout? So folks could post it here for others to try out?
I collapse the auxilliary viewport when I'm not using it.
Yep, find your settings in the DAZ folder in AppData/Roaming/DAZ 3D/Studio 4 (or Studio 4 Public Build)/user layouts. Identify the layout based on what you named it (I tend to name mine based on the date and Studio version, so it looks like: 12.29.20 4.14 Layout)
From there, you could save the Daz Script 2 (Ascii), Daz Shared XML, and PNG files (yes, all three) somewhere on your PC. Upload from that location if these forums allow it.
Mine (split across two screens: Left = 1080p, Right = 1440p)
