What does your Daz Layout look like?
Greetings
I have been running the default Daz theme/layout with everything in it's default location.
Lately, I've been noticing when I watch a Daz Tutorial, that often, the TUT Author's set up is far from the default.  I am guessing years of using Daz in all its iterations has honed their work flow to be as efficient for them as possible.
As I newbie though, color me intrigued.
If you are using something other than the default, you mind posting a screenshot and giving a tiny explantion of why-you-have-it-the-way-you-have-it?
I know everyone is different, but hey, I don't know what I don't know, so I love to see what works for you!
  • MimicMollyMimicMolly Posts: 2,380
    I use "Highway" default, with the "Smart Content", "DAZ Connect", and that one screen where it renders a preview of your viewport (because it slows my laptop down, so it's better without it), removed.
    Three monitors, left = Content Library, middle = Scene and Parameters, right = Viewport
    1843 x 384 - 44K
  • fixmypcmikefixmypcmike Posts: 19,742
    edited December 2020
    Mine is heavily customized -- no "rooms", no toolbars, lots of extra menus on the top menu bar.
    1598 x 860 - 149K
    Post edited by fixmypcmike on
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Mine isn't far from the default. I like the biggest veiwport I can get and all the panes I need have tabs along the side of the other window in the viewpoprt to the left. i also have my toolbar across the top and the most used items in the scripts dropdown
    I NEVER use smart content or connect and find everything thru the content library like it is installed.
    1920 x 1035 - 602K
  • lilweeplilweep Posts: 2,883
    i think i just use the default workspace.
    I put some effort into customisation a year or so ago but I didnt save as preset and lost it when i reinstalled.
    The only modification i made to my current layout was adding Mesh Grabber tool into the main tool menu.
  • marblemarble Posts: 7,500
    I too never use Smart Content or Connect so I have the Content tree open to find my stuff. I have quite a few Custom shortcuts, some of which I have created icons for and put them in various toolbars. Sometimes an update breaks the layout so I have to start over but maybe I find better options when I do that so I don't mind too much. The placing of actions/icons on the toolbars tends to be pretty unstable and it often happens that if I minimise the screen and then go back to Full Screen, they have all shifted position. A small annoyance but I can restore it by minimising and going back to Full Screen again.
    2560 x 1440 - 526K
    Post edited by marble on
    That is an interesting layout Marble. I like the icons to the side and top. Interesting that your library starts with DIM CONTENT.
  • Is it possible to export a layout?  So folks could post it here for others to try out?
    I collapse the auxilliary viewport when I'm not using it.
    1920 x 1050 - 448K
  • VisuimagVisuimag Posts: 578
    Yep, find your settings in the DAZ folder in AppData/Roaming/DAZ 3D/Studio 4 (or Studio 4 Public Build)/user layouts. Identify the layout based on what you named it (I tend to name mine based on the date and Studio version, so it looks like: 12.29.20 4.14 Layout)
    From there, you could save the Daz Script 2 (Ascii), Daz Shared XML, and PNG files (yes, all three) somewhere on your PC. Upload from that location if these forums allow it.
    Post edited by Visuimag on
    Mine (split across two screens: Left = 1080p, Right = 1440p)
    3890 x 1439 - 317K
